I made test backup from my Raspberry sd-card to usb-stick using SD Card Copier and now i need to rescue one text file from it.
Earlier when i plugged it in, it said "unrecognized format" or something similar, now it don's show any dialog but lsusb sees it and it don't appear in sidebar.
AFAIK, the SD Card Copier software writes an image of your SD card to a USB device - perhaps a USB-SD adapter, or a USB storage device?
NOTE: In general, more details make for better questions.
And so I will assume the following:
  • You have a working backup on a device that can be plugged into a USB port
  • Your RPi remains operational - you can read the USB device with the backup
  • You know how to open a terminal window & type commands into it
If this is your situation, you will only need to mount your USB device - after it is mounted, you can rummage through it as you wish, and find your text file.
  1. Plug the USB device containing the backup into a USB port on your RPi
  2. open a terminal & run the command: lsblk --fs
  3. verify that the USB device appears in the output - it should have two partitions: / and /boot
  4. mount the USB device or partition; ref man mount or read this
  5. find your text file, and copy it to your active SD card
Any follow-up questions should be made by editing your question, and include the output of lsblk --fs. This concludes "the answer"; I've added some unsolicited advice in the sequel that may help you in the future.
Unsolicited advice:
  • Forget SD Card Copier - there are better backup solutions. My favorite is image-utils
Seamus
  • 23,558
  • 83
