Similar to Can I power a Pi through a 5V pin?, but I want to acquire the 5V power source from another Pi. The first Pi gets its power via micro USB, and then I want to use pins 2 and 6 from that to power the second Pi via its 2 and 6 pins.
The trouble is every time I complete the connection, all power is lost on the first Pi and it shuts off (and the second one never lights up AFAIK).
I have confirmed that I can power the second Pi via pins 2 and 6 with 3 AA batteries. And of course pins 2 and 6 is supposed to deliver 5V power to another device. So why then can't I chain them together in this way?
Strictly speaking, this are Pi Zero W's.
7 Answers7
The Pi Zero has a basic power configuration i.e. NONE!
All the 5V pins are interconnected; there is absolutely no protection.
You could power one from another, but this seems pointless, and just involves running more current through the board traces.
Just run BOTH from the same 5V supply; it doesn't matter whether you use the dedicated USB port or the 5V pins.
In fact you can do this for ANY model Pi; the Foundation has recommendations on how to do it, but as the Zero has no protection, adding any seems superfluous. See Raspberry Pi Power Limitations
There is absolutely no way this could cause a shutdown (unless the power supply shuts down), although doing any connection to a running system, particularly if using significant current, is inadvisable.
You may have confirmed "I can power the second Pi via pins 2 and 6 with 3 AA batteries" - BUT don't expect it to run for long (or reliably). These are totally unsuitable for even the modest current required by the Pi Zero.
Your question is unclear wrt how the batteries are connected. However, battery connections aside, what you're doing is probably not a good idea. If you'd like to edit your question to include a schematic, perhaps we can answer more definitively.
However, your comment changes your question substantially:
One reason I want to chain them is to connect their GND pins, so that one Pi can decide to "short out" the RUN pin on the other simply by pulling a GPIO pin down to 0V.
You can tie ground pins from different RPi together without incurring the issues you'll face in tying the 5V input of one RPi to the 5V bus of another.
Seamus
  • 23,558
  • 83
As other pointed out already, why power it in a daisy-chain style when you can power both from the same power supply output? just derive two wires (or connectors) from there.
Also as pointed the Zero W has no internal power protection and its power traces may be too thin to handle the current necessary for the second Pi, hence the blackout when connecting it.
Also it is not clear what you are using as a 5V power supply, it is the three AAA cells? If so, maybe (just maybe) when connecting the second Pi the voltage comes lower than say 4,5V and is rendered unusable for the application.
That will work provided
  1. the power supplied to the first Pi is sufficient for its needs and the needs of the second Pi.
  2. that any polyfuse fitted to the first Pi will let sufficient current flow for both Pis.
I don't think the Pi Zeros have polyfuses so any failure is down to case 1.
joan
  • 71,852
  • 76
  • 108
Some USB power supplies are not great in maintaining 5v with peaky current requirements, even when they are quoted at 2.5 Amps. And poor power cabling will cause additional voltage drops along the way. With my Raspberry Pi battery power supply I did an experiment where I used one unit driving a Pi4 + LCD, USB Hub with Keyboard, Mouse and Webcam to also power a second battery board with a Pi3 and LCD. The Pi4 board was drawing around 2.5 Amps, the Pi3 another 2 Amps (as it was also charging that battery) when running a full graphics test on both. Note that power regulation will be critical to maintain a steady voltage. I made a video of it at https://youtu.be/DS3TtVOnquk .
Measure the voltage of the PSU with both loads applied. If it has dropped significantly below 5V you are definitely overloading it.
colintd
  • 367
use a usb hub for multiple raspberry pi power supply.
user135142
  • 44
