My installation is failing I think because I need to choose a wifi connection. I cannot use an ethernet cable so I need to start-up with the wifi.
David
Ubuntu server does not have WiFi support, and is not really designed for it.
It uses systemd-networkd for networking.
You may find some instructions on a Ubuntu site using yaml, although the last time I looked they use Network Manager for desktop installations. AFAIK it is not possible to install a DM as the Pi3B+ has insufficient memory for a Ubuntu installation.
I have done this using systemd-networkd on Raspberry Pi OS and the method should work on Ubuntu, although you will probably need to use Predictable Network Interface Names (and may need to install another application such as WPA supplicant).
