I am Raspberry Pi (3B) and the Pi converted wireless access point using Setting up a Raspberry Pi as an access point - the easy way and wlan0 works well. I repeated the process for wlan1 (USB adapter) as suggested by How to create two WiFi Access Points with a single Raspberry Pi with usb adaptor. When reboot wlan1 works but wlan0 stops working. The error message is very strange. When I am only using wlan0, it works perfectly but I got following results when both wlan0 and wlan1 connected. Status of both wlan1 and wlan0 are as follows
pi@raspberrypi:~ $ systemctl status wpa_supplicant@wlan1.service
● wpa_supplicant@wlan1.service - WPA supplicant daemon (interface-specific version)
   Loaded: loaded (/lib/systemd/system/wpa_supplicant@.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2021-05-30 14:30:30 AEST; 27min ago
 Main PID: 305 (wpa_supplicant)
   CGroup: /system.slice/system-wpa_supplicant.slice/wpa_supplicant@wlan1.service
           └─305 /sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlan1.conf -Dnl80211,wext -iwlan1
May 30 14:30:30 raspberrypi systemd[1]: Started WPA supplicant daemon (interface-specific version). May 30 14:30:30 raspberrypi wpa_supplicant[305]: Successfully initialized wpa_supplicant May 30 14:30:32 raspberrypi wpa_supplicant[305]: wlan1: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=AU May 30 14:30:33 raspberrypi wpa_supplicant[305]: Failed to create interface mon.wlan1: -95 (Operation not supported) May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: Could not connect to kernel driver May 30 14:30:33 raspberrypi wpa_supplicant[305]: Using interface wlan1 with hwaddr b8:27:eb:7e:78:7a and ssid "RPi1" May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: interface state UNINITIALIZED->ENABLED May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: AP-ENABLED May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: CTRL-EVENT-CONNECTED - Connection to b8:27:eb:7e:78:7a completed [id=0 id_str=]
pi@raspberrypi:~ $ systemctl status wpa_supplicant@wlan0.service ● wpa_supplicant@wlan0.service - WPA supplicant daemon (interface-specific version) Loaded: loaded (/lib/systemd/system/wpa_supplicant@.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2021-05-30 15:40:12 AEST; 26s ago Main PID: 2586 (wpa_supplicant) CGroup: /system.slice/system-wpa_supplicant.slice/wpa_supplicant@wlan0.service └─2586 /sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlan0.conf -Dnl80211,wext -iwlan0
May 30 15:40:12 raspberrypi systemd[1]: Started WPA supplicant daemon (interface-specific version). May 30 15:40:12 raspberrypi wpa_supplicant[2586]: Successfully initialized wpa_supplicant May 30 15:40:12 raspberrypi wpa_supplicant[2586]: nl80211: Could not configure driver mode May 30 15:40:12 raspberrypi wpa_supplicant[2586]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0 May 30 15:40:12 raspberrypi wpa_supplicant[2586]: rfkill: Cannot get wiphy information May 30 15:40:12 raspberrypi wpa_supplicant[2586]: ioctl[SIOCSIWAP]: Operation not permitted May 30 15:40:12 raspberrypi wpa_supplicant[2586]: ioctl[SIOCSIWENCODEEXT]: Invalid argument May 30 15:40:13 raspberrypi wpa_supplicant[2586]: wlan0: Driver does not support AP mode May 30 15:40:13 raspberrypi wpa_supplicant[2586]: wlan0: Driver does not support AP mode
The status of systemd-networkd.service
pi@raspberrypi:~ $ systemctl status systemd-networkd.service
● systemd-networkd.service - Network Service
   Loaded: loaded (/lib/systemd/system/systemd-networkd.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2021-05-30 14:30:28 AEST; 29min ago
     Docs: man:systemd-networkd.service(8)
 Main PID: 142 (systemd-network)
   Status: "Processing requests..."
   CGroup: /system.slice/systemd-networkd.service
           └─142 /lib/systemd/systemd-networkd
May 30 14:30:28 raspberrypi systemd-networkd[142]: Enumeration completed May 30 14:30:28 raspberrypi systemd[1]: Started Network Service. May 30 14:30:29 raspberrypi systemd-networkd[142]: eth0: IPv6 enabled for interface: Success May 30 14:30:29 raspberrypi systemd-networkd[142]: wlan0: IPv6 enabled for interface: Success May 30 14:30:31 raspberrypi systemd-networkd[142]: eth0: Gained carrier May 30 14:30:33 raspberrypi systemd-networkd[142]: wlan1: Gained carrier May 30 14:30:33 raspberrypi systemd-networkd[142]: eth0: Gained IPv6LL May 30 14:30:34 raspberrypi systemd-networkd[142]: wlan1: Gained IPv6LL May 30 14:30:36 raspberrypi systemd-networkd[142]: eth0: DHCPv4 address 10.0.0.23/24 via 10.0.0.138 May 30 14:30:47 raspberrypi systemd-networkd[142]: wlan1: Configured
When I added wlan1, wlan0 stops working, why? I really appreciate any help.
Raj
