I am trying to set up a apache james mail server on my raspberry pi 4 https://james.apache.org/server/quick-start.html but i get this error when i run the ./james
schmax@ubuntu:~/james/james-server-app-3.6.0/bin$ ./james
Unable to locate any of the following operational binaries:
  /home/schmax/james/james-server-app-3.6.0/bin/./wrapper-linux-aarch64-64
  /home/schmax/james/james-server-app-3.6.0/bin/./wrapper-linux-aarch64-32
  /home/schmax/james/james-server-app-3.6.0/bin/./wrapper (Found but not executable.)
schmax@ubuntu:~/james/james-server-app-3.6.0/bin$ ./james start Unable to locate any of the following operational binaries: /home/schmax/james/james-server-app-3.6.0/bin/./wrapper-linux-aarch64-64 /home/schmax/james/james-server-app-3.6.0/bin/./wrapper-linux-aarch64-32 /home/schmax/james/james-server-app-3.6.0/bin/./wrapper (Found but not executable.) schmax@ubuntu:~/james/james-server-app-3.6.0/bin$
I am sure that it can work on a Pi.
However, it looks to me like james is not pure java and so that package includes pre-built binaries. They will be compiled for x86(-64) and will not work on any model of Pi.
You need to start with the "Source code" version from here: https://james.apache.org/download.cgi#Apache_James_Server
There is documentation for doing that:
https://james.apache.org/server/install.html
You need to follow the "If you have downloaded a source package, process [sic] first to the build..." track; the "build" link is:
https://james.apache.org/server/dev-build.html
I came across the same issue when attempting to run Apache James on my Raspberry Pi.
I'm using Apache James 3.7.2 with Spring wiring.
The bin/james script uses a wrapper to kick off the Java process from Tanuki software.
https://wrapper.tanukisoftware.com
Presumably this is for convenience when trying to run James as a service. If you have a look through conf/wrapper.conf it configures the wrapper to run the JamesAppSpringMain Java class.
There is an alternative script provided in the distribution - bin/run.sh. This script also executes the same Java class JamesAppSpringMain but without using the service wrapper.
I found that using the bin/run.sh script works fine on my Raspberry Pi without any problems.
Another option is to download the Linux ARM (AArch64) version of the service wrapper. The Tanuki website does list the 64 bit version as being available.
https://wrapper.tanukisoftware.com/doc/english/download.jsp#stable
I haven't tried this as I was satisfied using the bin/run.sh script.
Frank
