The setup Hardware:
  • Raspberry Pi 4
  • 2 ethernet ports (one via USB ethernet)
  • one switch
Software:
  • Raspbian 10 (buster)
  • Pi-hole active as DNS server without DHCP (until now the router takes care of that)
  • Unbound as DNS provider
  • Network Traffic scanner (Network Monitor)
IP:
  • eth0 = 192.168.178.2
  • eth1 = 192.168.178.3
  • wlan0 = 192.168.178.4 (if needed)
  • DNS = 127.0.0.1 (because of unbound)
  • DHCP = 192.168.178.1 (local router)
I want the connection with everything to look like this: ISP -> Router -> Raspbarry -> Switch -> Endpoints
So the Raspbarry should forward the packets through its eth0 to eth1 (where the switch is). Everything that goes through eth0 should be recorded (via network monitoring). Not one single instruction helps me completely (because they are all outdated and don't work anymore).
When I try to make a bridge from eth0 to eth1, I can't access my Raspbarry at all and have to reset it.
Can someone help me please?
From the official Raspberry documentation (Setting up a Raspberry Pi as a bridged wireless access point) I took the following and tried to implement it:
sudo nano /etc/systemd/network/bridge-br0.netdev
[NetDev] name=br0 type=bridge
sudo nano /etc/systemd/network/br0-member-eth0.network
[Match] Name=eth0
[network] bridge=br0
sudo systemctl enable systemd-networkd
sudo nano /etc/dhcpcd.conf
denyinterfaces eth0 eth1 interface br0
my dhcpcd.conf looks like this
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
Inform the DHCP server of our hostname for DDNS.
hostname
Use the hardware address of the interface for the Client ID.
clientid
or
Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
Some non-RFC compliant DHCP servers do not reply with this set.
In this case, comment out duid and enable clientid above.
#duid
Persist interface configuration when dhcpcd exits.
persistent
Rapid commit support.
Safe to enable by default because it requires the equivalent option set
on the server to actually work.
option rapid_commit
A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name option classless_static_routes
Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
Most distributions have NTP support.
#option ntp_servers
A ServerID is required by RFC2131.
require dhcp_server_identifier
Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
Example static IP configuration:
#interface eth0 #static ip_address=192.168.178.2/24 #static ip6_address=fd51:42f8:caae:d92e::ff/64 #static routers=192.168.178.1 #static domain_name_servers=192.168.178.1 8.8.8.8 fd51:42f8:caae:d92e::1
It is possible to fall back to a static IP if DHCP fails:
define static profile
#profile static_eth0 #static ip_address=192.168.1.23/24 #static routers=192.168.1.1 #static domain_name_servers=192.168.1.1
fallback to static profile on eth0
#interface eth0 #fallback static_eth0
denyinterfaces eth0 eth1 interface eth0 static ip_address=192.168.178.2/24 static routers=192.168.178.1 static domain_name_servers=8.8.8.8 8.8.4.4
interface eth0 fallback static_eth0
interface eth1 static ip_address=192.168.178.3/24 static routers=192.168.178.1 static domain_name_servers=8.8.8.8 8.8.4.4
interface eth1 fallback static_eth1
interface wlan0 static ip_address=192.168.178.4/24 static routers=192.168.178.1 static domain_name_servers=8.8.8.8 8.8.4.4
interface wlan0 fallback static_wlan0
interface br0
The dnsmasq-pihole settings looks like this:
# Pi-hole: A black hole for Internet advertisements
# (c) 2017 Pi-hole, LLC (https://pi-hole.net)
# Network-wide ad blocking via your own hardware.
# Dnsmasq config for Pi-hole's FTLDNS
# This file is copyright under the latest version of the EUPL.
# Please see LICENSE file for your rights under this license.
FILE AUTOMATICALLY POPULATED BY PI-HOLE INSTALL/UPDATE PROCEDURE.
ANY CHANGES MADE TO THIS FILE AFTER INSTALL WILL BE LOST ON THE NEXT UPDATE
IF YOU WISH TO CHANGE THE UPSTREAM SERVERS, CHANGE THEM IN:
/etc/pihole/setupVars.conf
ANY OTHER CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE
WITHIN /etc/dnsmasq.d/yourname.conf
addn-hosts=/etc/pihole/local.list addn-hosts=/etc/pihole/custom.list
localise-queries
no-resolv
cache-size=10000
log-queries log-facility=/var/log/pihole.log
local-ttl=2
log-async server=127.0.0.1#5335 domain-needed expand-hosts bogus-priv local-service server=/use-application-dns.net/
I need to be sure that eth0 is IP 192.168.178.2 and eth1 is 192.168.178.3. Whatever is behind eth1 can get a DHCP address. That's why I put the Static IP.
I do not have much experience in bridging. That's why I don't know how to customize something so that it works.
