What are the solutions to locally schedule the power on / power off of a Raspberry (power on at 8 am and power off at 8 pm) ? I was asked to do so by the person in charge of my project. I told him it has to be done by plugin an additional device such as PiJuice or PiWatcher (I'm new to Raspberry sorry if I'm wrong on these) since I was told that by internet and a teacher. Is it really true, there are no way to script that, like cron for example?
I have a Pi0, soon will have a Pi4 instead I believe.
Axel Carré
  • 103
You can't use a script running on the Pi to switch the Pi on when off. I leave it to you to work out why a script will not work if the Pi is not powered.
You need an external device to switch the power on.
Why do you need to switch the power on and off? You could use a script to reboot the Pi.
joan
  • 71,852
  • 76
  • 108
Reading the comments to @joan's answer, it occurs to me that you might be open to "Low Power" in lieu of "Zero Power".
If that's the case, and your RPi model is 4B you can reduce the current draw to about 35-40 mA (200mW) by changing a couple of configuration variables in your EEPROM bootcode. See this answer for details.
You can schedule entry into "Low Power" power mode programmatically (e.g. cron), but you will still need external hardware (a momentary push-button switch) to restore the RPi to an operational state. If it must be automated, this can be done with the DS3231 Realtime Clock (RTC) to pull the GLOBAL_EN via on the PCB low at the specified time. Additional hardware is required to automate wakeup, but software-wise this is supported by the kernel via a dtoverlay.
If you actually do need "Zero Power", you can also get that, but NOT through the EEPROM bootcode. And it will require a bit more external hardware. I won't go on as I'm not sure which solution you're committed to, but feel free to ask another question, or edit this one.
In summary then:
  1. You can enter "Low Power mode" by properly setting two (2) config variables in the bootcode stored in EEPROM but you can't exit "Low Power mode" without external hardware.
  2. You can enter "Zero Power mode" using the dtoverlay=gpio-poweroff in /boot/config.txt. This will require additional hardware; perhaps a RTC and a PMIC.
  3. You cannot have them both (Zero Power and Low Power). I cannot explain why this is, but will refer you to The Organization's experts.
Seamus
  • 23,558
  • 83
