I'm trying to install Brackets.io on the Pi. But the "create-project" step in Grunt is not very pleased with that try. It tells me that it can't find the gtk+-2.0, nor the gthread-2.0 libraries and that I better check my PKG_CONFIG_PATH environment variables.
When I do a "sudo apt-get install gtk+-2.0" it tells me that it'll use gir1.2-gtk-2.0 instead... so I guess I could change the appshell.gyp file so that it looks for gir instead of gtk+... no problem there... I hope at least.
But when I do a "sudo apt-get install gthread-2.0" it response immediately that it can't find that library... "Unable to locate package gthread-2.0". Any idea's how to fix that ?
You need the -dev packages in addition to the normal one if you want to compile against the library.
> apt-cache search gtk+-2.0
libgtk2.0-dev - development files for the GTK+ library
> apt-get install libgtk2.0-dev
Gthreads are part of glib, so the dev package should be:
> apt-get install libglib2.0-dev
