Back again with the same issue (previously it was 5.4.51 -> 5.4.83 Kernel version does not update when using apt update, apt full-upgrade, got no useful suggestions) - now it's 5.4.83 -> 5.10.17. This is the moving from the 2nd latest RaspberryPiOS(c) release to the latest RaspberryPiOS release.
Last time I ended up installing 5.4.83 fresh after börking the 5.4.51 trying to update linux on 2 Rpi's (2B and 3B) that are setup the same. I assume most people aren't having this issue since updating an OS shouldn't be this hard, even if it is Linux. I can get to 5.10.17 if I do a clean reinstall, but that's no way to live.
The obvious maneuver:
sudo reboot
sudo apt update
sudo apt full-upgrade
sudo reboot
Doesn't lead to an update:
Linux wiipii 5.4.83-v7+ #1379 SMP Mon Dec 14 13:08:57 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon Mar 29 23:19:32 2021 from 192.168.1.2 dmptrk@wiipii:~ $ sudo apt update [sudo] password for dmptrk: Hit:1 http://packages.microsoft.com/repos/code stable InRelease Hit:2 http://archive.raspbian.org/raspbian testing InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:5 http://packages.azlux.fr/debian buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. dmptrk@wiipii:~ $ sudo apt full-upgrade [sudo] password for dmptrk: Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Last time I tried rpi-update and that bjorked the 3B, and deleting the kernel-related entries in sudo nano /var/lib/dpkg/status and then refreshing it and updating from there bonked the 2B. The SD cards are fine, the hardware is fine, if I wipe it and flash to 5.10.17 right now it'll work and I'll just have to set it all up again.
What can I do to update my rpis? What am I doing that's making it not work? I gotta be doing something to muck this up - but I'm not sure what or how to see what's going wrong.
Note I have Hit:2 http://archive.raspbian.org/raspbian testing InRelease as a repo to hit from adding Wireguard support per https://www.sigmdel.ca/michel/ha/wireguard/wireguard_02_en.html 's
echo "deb http://archive.raspbian.org/raspbian testing main" | sudo tee --append /etc/apt/sources.list.d/testing.list
printf 'Package: *\nPin: release a=testing\nPin-Priority: 50\n' | sudo tee --append /etc/apt/preferences.d/limit-testing
The lower priority means it doesn't supersede anything that's in other repos, so it effects Wireguard and that's it. I understand 5.10 comes with Wireguard in the kernel and that'll be a great thing to deal with after updating to 5.10.
user2403531
  • 137
I backtracked commands and programs (deleting and unsetting settings) and trying apt full-upgrade each time until I hit what caused the raspberry-kernel to be removed from the upgrade list.
Turns out it was the testing branch for wireguard in Rpi kernel 5.4.XX, it was added with the code:
per the guide for installing wireguard on 5.4.XX-based Rpi's: https://www.sigmdel.ca/michel/ha/wireguard/wireguard_02_en.html
I deleted the entries in the testing.list and limit-testing and raspberry-kernel showed up in apt full-upgrade, added those entries back it and it disappeared.
I'm not sure why this caused an issue, since the raspbian testing repo had a low priority set so it wouldn't effect anything that was also in main repos. But I barely figured this out, so I won't try to divine what went wrongk in apt's raspberry-kernel upgrade calculations.
Good news is that removing wireguard and the testing repo allowed for upgrading to the (currently) latest 5.10.17 kernel, and the 5.10.17 kernel has wireguard included in the kernel. You need to install wireguard-tools to use wireguard but wireguard-tools has been added to the main repos and can be installed with sudo apt install wireguard-tools without any repo shenanigans. This means that for future kernel upgrades I shouldn't have this issue since I don't have to use the testing branch anymore with the latest 5.10.17 kernel.
user2403531
  • 137
