I'm trying to test the audio through the headphone jack using aplay /usr/share/sounds/alsa/* on Rasbian 5.10.17 on a Raspberry Pi 3 B+. This works fine on the pi user, but not on root or another user I've created for my projet. When running the command using 1) sudo, 2) logging in as root using sudo -i, or 3) logged in as the other user, I get the same error:
aplay: set_params:1403: Unable to install hw params:
ACCESS:  RW_INTERLEAVED
FORMAT:  S16_LE
SUBFORMAT:  STD
SAMPLE_BITS: 16
FRAME_BITS: 16
CHANNELS: 1
RATE: 48000
PERIOD_TIME: 125000
PERIOD_SIZE: 6000
PERIOD_BYTES: 12000
PERIODS: 4
BUFFER_TIME: 500000
BUFFER_SIZE: 24000
BUFFER_BYTES: 48000
TICK_TIME: 0
The weird thing is that it plays the first file /usr/share/sounds/alsa/Front_Center.wav, but the error occurs on the second file. I've tried to add the other user to relevant groups such as audio, pulse, dialout, cdrom, video, plugdev, etc. Basically the same groups as the pi user.
The second issue is that when using espeak for text-to-speech the screen is filled with errors:
other-user@raspberrypi:~ $ espeak "hello"
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback ALSA lib conf.c:5014:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0} ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0} ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card Cannot connect to server socket err = No such file or directory Cannot connect to server request channel jack server is not running or cannot be started JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
The same errors occurs for the three cases 1)-3) above.
Using omxplayer works fine in all the three cases 1)-3) above, it is only aplay and espeak there are troubles with. So running espeak with the -w argument works and playing it using omxplayer works, but is not ideal.
What is the problem? How can I fix it?
Some more information:
Running aplay -l I get:
**** List of PLAYBACK Hardware Devices ****
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
and aplay -L
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
jack
    JACK Audio Connection Kit
pulse
    PulseAudio Sound Server
sysdefault:CARD=Headphones
    bcm2835 Headphones, bcm2835 Headphones
    Default Audio Device
dmix:CARD=Headphones,DEV=0
    Direct sample mixing device
dsnoop:CARD=Headphones,DEV=0
    Direct sample snooping device
hw:CARD=Headphones,DEV=0
    Direct hardware device without any conversions
plughw:CARD=Headphones,DEV=0
    Hardware device with all software conversions
usbstream:CARD=Headphones
    bcm2835 Headphones
    USB Stream Output
eirik-ff
  • 121
When your custom user fails to play the audio, are you also logged to the system as the pi user? audio group is tricky, it allows users in that group to get exclusive access to audio HW, preventing other users from using it:
Adding users to the audio group allows direct access to devices. Keep in mind, that this allows applications to exclusively reserve output devices. This may break software mixing or fast-user-switching on multi-seat systems. Therefore, adding a user to the audio group is not recommended by default; unless you specifically need to.
And from the Ubuntu wiki:
As a practical rule of thumb for Debian and Ubuntu systems, there should be no users in the audio group.
Pi OS is configured in a way to make everything work for the pi user, more or less exclusively, because it will make it easy for 99% of the users. That's why pi is in the audio group. One solution is to use the pi user in your project, as intended.
If you must have a different user for this project, consider removing the pi user from the audio group, or even stopping using it altogether. Than means no auto-login as pi, and no manual logins. You should even be able to remove the pi user completely.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
Caveat: I know nothing about aplay or espeak. However, I can sometimes read & comprehend a man page. Simon's answer may be generally correct in that your "other-user" needs to be added to the group audio, but I don't believe you can add a user to a group with the command he's given: sudo useradd -G audio. To be completely fair, group and user administration on Debian (and therefore RPi OS) is confusing!
_If_ adding "other-user" to the group audio is the solution, try this instead (as user pi):
pi@raspberrypi:~ $ sudo usermod -a -G audio other-user
Note: that is usermod - not useradd
Afterwards, you can check that this was successful (again, as user pi):
pi@raspberrypi:~ $ groups other-user
You should see the group audio in the output list.
Seamus
  • 23,558
  • 83
You need to add your user into the 'audio' group to allow them access to audio devices and resources.
sudo useradd -G audio <Your username>
Simon Banks
  • 610
