I installed after the light raspbian version sudo apt install raspberrypi-ui-mods which installs pixel desktop manager. After that I'm trying to have an automated script that enables the GUI without having to pass through raspi-config. Did not find any way to do that, which configuration file does it go to modify!! I'd like it without user auto-login
- 277
- 3
- 14
If the reason why you don't want to use raspi-config is because you want to automate it and not have to go through the interactive menu, you can also use the script in a noninteractive way (see also this Q&A e.g.):
raspi-config nonint function options
will directly execute the internally defined function that does the actual work, and which in the interactive mode would be triggered by your menu choice.
In your case
raspi-config nonint do_boot_behaviour B3
will enable the graphical login, just as if you had chosen "1: System Options" -> "S5: Boot/Auto Login" -> "B3: Desktop" in the interactive mode. If you want to choose the "auto-login" graphical boot, use
raspi-config nonint do_boot_behaviour B4
instead.
- 264
- 2
- 16
Here's the script that raspi-config runs when you enable the GUI without autologin:
systemctl set-default graphical.target
ln -fs /lib/systemd/system/getty@.service /etc/systemd/system/getty.target.wants/getty@tty1.service
rm /etc/systemd/system/getty@tty1.service.d/autologin.conf
sed /etc/lightdm/lightdm.conf -i -e "s/^autologin-user=.*/#autologin-user=/"
You may need to edit a different config file if you have a different desktop manager.
- 28,277
- 6
- 54
- 147
