For all Raspberry Pis I would assume the expansion header GPIO are always on /dev/gpiochip0.
It would be an extremely perverse decision to place them on any other gpiochip.
For reference the Pi4B has two gpiochips.
gpiochip0
lines=58 name=gpiochip0 label=pinctrl-bcm2711
offset=0 flags=0 name=ID_SDA user=
offset=1 flags=0 name=ID_SCL user=
offset=2 flags=0 name=SDA1 user=
offset=3 flags=0 name=SCL1 user=
offset=4 flags=0 name=GPIO_GCLK user=
offset=5 flags=0 name=GPIO5 user=
offset=6 flags=0 name=GPIO6 user=
offset=7 flags=0 name=SPI_CE1_N user=
offset=8 flags=0 name=SPI_CE0_N user=
offset=9 flags=0 name=SPI_MISO user=
offset=10 flags=0 name=SPI_MOSI user=
offset=11 flags=0 name=SPI_SCLK user=
offset=12 flags=0 name=GPIO12 user=
offset=13 flags=0 name=GPIO13 user=
offset=14 flags=0 name=TXD1 user=
offset=15 flags=0 name=RXD1 user=
offset=16 flags=0 name=GPIO16 user=
offset=17 flags=0 name=GPIO17 user=
offset=18 flags=0 name=GPIO18 user=
offset=19 flags=0 name=GPIO19 user=
offset=20 flags=0 name=GPIO20 user=
offset=21 flags=0 name=GPIO21 user=
offset=22 flags=0 name=GPIO22 user=
offset=23 flags=0 name=GPIO23 user=
offset=24 flags=0 name=GPIO24 user=
offset=25 flags=0 name=GPIO25 user=
offset=26 flags=0 name=GPIO26 user=
offset=27 flags=0 name=GPIO27 user=
offset=28 flags=0 name=RGMII_MDIO user=
offset=29 flags=0 name=RGMIO_MDC user=
offset=30 flags=0 name=CTS0 user=
offset=31 flags=0 name=RTS0 user=
offset=32 flags=0 name=TXD0 user=
offset=33 flags=0 name=RXD0 user=
offset=34 flags=0 name=SD1_CLK user=
offset=35 flags=0 name=SD1_CMD user=
offset=36 flags=0 name=SD1_DATA0 user=
offset=37 flags=0 name=SD1_DATA1 user=
offset=38 flags=0 name=SD1_DATA2 user=
offset=39 flags=0 name=SD1_DATA3 user=
offset=40 flags=0 name=PWM0_MISO user=
offset=41 flags=0 name=PWM1_MOSI user=
offset=42 flags=3 name=STATUS_LED_G_CLK user=led0
offset=43 flags=0 name=SPIFLASH_CE_N user=
offset=44 flags=7 name=SDA0 user=spi0 CS0
offset=45 flags=7 name=SCL0 user=spi0 CS1
offset=46 flags=0 name=RGMII_RXCLK user=
offset=47 flags=0 name=RGMII_RXCTL user=
offset=48 flags=0 name=RGMII_RXD0 user=
offset=49 flags=0 name=RGMII_RXD1 user=
offset=50 flags=0 name=RGMII_RXD2 user=
offset=51 flags=0 name=RGMII_RXD3 user=
offset=52 flags=0 name=RGMII_TXCLK user=
offset=53 flags=0 name=RGMII_TXCTL user=
offset=54 flags=0 name=RGMII_TXD0 user=
offset=55 flags=0 name=RGMII_TXD1 user=
offset=56 flags=0 name=RGMII_TXD2 user=
offset=57 flags=0 name=RGMII_TXD3 user=
gpiochip1
lines=8 name=gpiochip1 label=raspberrypi-exp-gpio
offset=0 flags=2 name=BT_ON user=
offset=1 flags=2 name=WL_ON user=
offset=2 flags=7 name=PWR_LED_OFF user=led1
offset=3 flags=2 name=GLOBAL_RESET user=
offset=4 flags=3 name=VDD_SD_IO_SEL user=vdd-sd-io
offset=5 flags=2 name=CAM_GPIO user=
offset=6 flags=3 name=SD_PWR_ON user=sd_vcc_reg
offset=7 flags=0 name=SD_OC_N user=
My laptop has four gpiochips. I only show the lines field as the name and user fields are blank.
lines=80 name=gpiochip0 label=INT3453:00
lines=80 name=gpiochip1 label=INT3453:01
lines=20 name=gpiochip2 label=INT3453:02
lines=35 name=gpiochip3 label=INT3453:03
