10
I'm trying to set up a video conferencing system by using two Raspberry Pi boards.
How can I stream the H.264 protocol over a real-time streaming protocol via an Ethernet connection?
Which OS should I use to develop on the Raspberry Pi board?
Peter Mortensen
  • 2,004
sujal
  • 101
EDIT: This is not with RTSP but may help you
You can try with How to stream video and audio from a Raspberry Pi with no latency.
Install gstreamer1.0 on the Raspberry Pi video server:
  1. In /etc/apt/sources.list, add "deb http://vontaene.de/raspbian-updates/ . main"
  2. sudo apt-get update
  3. sudo apt-get install gstreamer1.0
Start streaming the video
  1. In the Raspberry Pi with command:
    raspivid -t 0 -w 1080 -h 720 -fps 25 -hf -b 2000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=VIDSERVERIP port=5000
Start receiving video
  1. On your PC, type the command:
    gst-launch-1.0 -v tcpclientsrc host=VIDSERVERIP port=5000 ! gdpdepay ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink sync=false
inye
  • 159
I posted a possible solution in raspberry forum using a simple RTSP server based on live555 that is fed with H264 V4L2 driver that you can find from github h264_v4l2_rtspserver
mpromonet
  • 1,124
  • 38
There is a custom source called nginx-rtmp - This works really well but you need to do quite allot of things before it works. It is awesome because it has allot of built in features and supports other streaming protocols, like HLS or embedding MPEG-DASH into websites, not just RTMP. It is extremely efficient in repackaging the video stream into flv or mp4.
Here is a blog post on how to get it working.
The only serious prerequisite is ffmpeg needs to be compiled on Rasbpian (Do not use the repo one it is slow) from the newest fork. I think on Arch it has the correct ffmpeg. This takes 5 hours on the Pi. Try and find a compiled version or use qemo to cross compile.
But in a nutshell using nginx 1.4.1 (you can try newer if you need to)
 cd /usr/scr
 #clone the latest version of rtmp module for nginx
 git clone git://github.com/arut/nginx-rtmp-module.git
 #download nginx source tested with- 1.4.1  but 1.5.0 is also supported
 wget http://nginx.org/download/nginx-1.4.1.tar.gz
 tar xzf nginx-1.4.1.tar.gz
 cd nginx-1.4.1
You need to get dependencies (check the link to the blog) for building and nginx. Then you configure the build inside the nginx source linking to the rtmp module. The build takes 10 minutes on the Pi.
 ./configure --prefix=/var/www \
             --sbin-path=/usr/sbin/nginx \
             --conf-path=/etc/nginx/nginx.conf \
             --pid-path=/var/run/nginx.pid \
             --error-log-path=/var/log/nginx/error.log \
             --http-log-path=/var/log/nginx/access.log \
             --with-http_ssl_module \
             --without-http_proxy_module \
             --add-module=/usr/src/nginx-rtmp-module \
The latest version of Raspbian includes the UV4L driver that fixes the PSIPS (the time frame embedding for h264 that was broken in the original raspivid drivers.) So that should fix quite allot of streaming issues now.
Piotr Kula
  • 17,336
  • 66
  • 105
Here's a recipe to get you started: Sending and receiving PI Camera video over the network
Peter Mortensen
  • 2,004
hendry
  • 197
