I have successfully installed and used pydbus to communicate and control a few Bluetooth LE devices from a Raspberry Pi (full version).
When I tried to do the same with Raspbian lite, I got:
object does not export any interfaces; you might need to pass object path as the 2nd argument for get()'
Which I don't get how this has occurred. Am i missing something in the Raspbian lite?
R.M.S.Sundram
This is commonly because the pi user's privileges are different on the full version than they are on a Lite installation.
For example, user pi on a Desktop RPi system is able to start and control the default Bluetooth controller using bluetoothctl, but not on a RPi Lite system.
For example, are you seeing no controller if you use bluetoothctl?
pi@raspberrypi4b:~ $ bluetoothctl
[bluetooth]# list
No default controller available
The solution seems to be to add user pi to group bluetooth:
pi@raspberrypi4b:~ $ sudo usermod -G bluetooth -a pi
This should resolve the bluetoothctl and pydbus issue.
ukBaz
  • 1,548
