Brief:
In a previous question I asked whether multiple IPs can be assigned via DHCP and reserved by a single Raspberry Pi. The accepted answer demonstrates how to achieve this by setting up virtual network interfaces linked to eth0 and assigning a unique MAC address to the interface.
When I attempt the same steps using wlan0 instead of eth0 I get IPs allocated on the 192.254.x.x subnet, which suggests there is an issue reaching the DHCP server.
Is there a reason this process would work for eth0 but not wlan0?
Details:
I start by loading the latest Raspbian image onto my Raspberry Pi (Buster 2021-01-11).
I create a file /etc/network/interfaces.d/eth0 and write the following:
auto eth0
iface eth0 inet manual
  up ip link add link eth0 name eth0.01 address 02:00:00:00:00:01 type macvlan
  up ip link add link eth0 name eth0.02 address 02:00:00:00:00:02 type macvlan
I create a file /etc/network/interfaces.d/wlan0 and write the following:
auto wlan0
iface wlan0 inet manual
  up ip link add link wlan0 name wlan0.01 address 02:00:00:00:00:A1 type macvlan
  up ip link add link wlan0 name wlan0.02 address 02:00:00:00:00:A2 type macvlan
These settings are applied with the command:
sudo systemctl restart networking
Let's WiFi tether to an Android cell phone. Hopefully this is an easily repeatable setup; it implements a DHCP server at 192.168.43.1/24 using netd to handle the tethering using dnsmasq. To try to keep things comparable between the eth0 and wlan0 interface I use a DLink WiFi extender to wirelessly tether to the Android's WiFi Hotspot and forward a WiFi signal to the Raspberry Pi's wlan0 and an ethernet cable to connect to the Raspberry Pi's eth0 interfaces.
I use the following command to see what my IP addresses are for each interface:
ifconfig
Here is a summary of the lines of code that are of interest:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.43.233  netmask 255.255.255.0  broadcast 192.168.43.255
eth0.01: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.43.41 netmask 255.255.255.0 broadcast 192.168.43.255
eth0.02: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.43.54 netmask 255.255.255.0 broadcast 192.168.43.255
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.43.76 netmask 255.255.255.0 broadcast 192.168.43.255
wlan0.01: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 169.254.36.195 netmask 255.255.0.0 broadcast 169.254.255.255
wlan0.02: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 169.254.75.246 netmask 255.255.0.0 broadcast 169.254.255.255
It is clear that the wlan0.01 and wlan0.02 interfaces are not communicating with the DHCP server (as seen by the IPs starting with 169.254), whereas the eth0.01 and eth0.02 interfaces are.
Can I reserve two IPs via the wlan0 interface?
Starting with the question:
There is a difference in how the eth0 interface treats packets compared to wlan0. A comment on a blog post poses a plausible explanation:
I read somewhere that wireless doesn't work because frames coming in are then found to have a 'wrong' mac address. The frames contain a mac address of the physical device but appear to have come in through the macvlan's mac address. This is seen as suspicious and the frame gets dropped.
I tried to solve the problem systemd-networkd style networking. However, much of my experience was the same as what you can see in the original question where /etc/network/interface.d/ is used. That is, macvlan interfaces worked with eth0 without too much difficulty, but macvlan interfaces do not play well with wlan0.
To answer the underlying problem:
The short answer is:
  • Yes
However, the solution I found is not great. I couldn't add any more than a single virtual interface. It appears to be sensitive to the name given to the virtual interface. It appears to be sensitive to the MAC address given to the interface. It has even been observed to drop out. I would not recommend as a permanent solution.
Assuming you already have set up your WiFi, copy/rename the wifi configuration information:
sudo cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
Disable networking and dhcpcd and enable systemd-networkd:
sudo systemctl enable systemd-networkd
sudo systemctl disable dhcpcd
sudo systemctl disable networking
sudo systemctl enable systemd-resolved.service
sudo systemctl disable wpa_supplicant.service
sudo systemctl enable wpa_supplicant@wlan0.service
Create file /etc/systemd/network/wlan0.network:
[Match]
Name=wlan0
[Network] DHCP=ipv4 MACVLAN=vlan0 LinkLocalAddressing=no
Create file /etc/systemd/network/vlan0.network:
[Match]
Name=vlan0
[Network] DHCP=yes LinkLocalAddressing=no
Create file /etc/systemd/network/vlan0.netdev:
[NetDev]
Name=vlan0
Kind=macvlan
MACAddress=2e:d5:1e:d7:a9:4f
[MACVLAN] Mode=passthru
Apply the settings and view the IP address settings
systemctl restart systemd-networkd ; sleep 2 ; ip a
It can be seen that two wlan0 IPs are present, both are ping-able from the wider network:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether b8:27:eb:4e:c3:b6 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:1b:96:e3 brd ff:ff:ff:ff:ff:ff
    inet 192.168.43.78/24 brd 192.168.43.255 scope global dynamic wlan0
       valid_lft 3318sec preferred_lft 3318sec
4: vlan0@wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.43.76/24 brd 192.168.43.255 scope global dynamic vlan0
Repeating with eth0 instead of wlan0 works without issue. It even lets you add multiple macvlan interfaces.
Here are my sources: link link link link link link link link
This is an XY problem.
You have decided (for whatever reason) that you "need" multiple IP addresses for the same interface and are diving more deeply into that rabbit hole (mixing incompatible networking systems without understanding either).
It may be possible to achieve your primary goal, but first you have to clearly define exactly what you are trying to achieve - you certainly won't by mixing Debian networking and dhcpcd.
NOTE you are further complicating your problem by using the deprecated ifconfig rather than ip a.
