How I do it over ssh to backup my Pi 4 to my ssd drive. Firstly you need to put your ssh id the .ssh/id_rsa.pub of the user running the rsync command into the /root/.ssh/authorized_keys file you copy the contents into the /root file or you need to allow root login via ssh. The key file is best for passwordless login.
Next you need to prepare your disk to be copied to, an example of it below made with fdisk.
the commands to make it are the same as with the gdisk I show below with one exception you need to do an "a",
the single letter, command after the partitioning and before the writing too select the 1 partition and make it active or a MBR drive will not boot, then on to formatting like I show there too and now I think
0b for the type of the first boot partition, FAT 32, and 8300 for the second no difference with gdisk..
root@zeus-H370M-DS3H:/home/zeus# fdisk -l /dev/sdc
Disk /dev/sde: 111.79 GiB, 120034123776 bytes, 234441648 sectors
Disk model: SH103S3120G
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: dos
Disk identifier: 0xa62408c8
Device Boot Start End Sectors Size Id Type
/dev/sdc1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sdc2 532480 234441647 233909168 111.5G 83 Linux
To prepare your disk as GPT as I discovered the Pi 4 will boot from GPT partitioned drive
when I forgot make the boot partition active with fdisk. It had the warning no GPT found then after it gives up searching it goes onto booting MBR drive, we never get to see it as it is only visible with a text boot.
root@zeus-H370M-DS3H:/home/zeus# dd if=/dev/zero of=/dev/sde bs=512 count=34
34+0 records in
34+0 records out
17408 bytes (17 kB, 17 KiB) copied, 0.00286715 s, 6.1 MB/s
root@zeus-H370M-DS3H:/home/zeus# dd if=/dev/zero of=/dev/sde bs=512 count=34 seek=$((`blockdev --getsz /dev/sde` - 34))
34+0 records in
34+0 records out
17408 bytes (17 kB, 17 KiB) copied, 0.00584954 s, 3.0 MB/s
root@zeus-H370M-DS3H:/home/zeus# gdisk /dev/sde
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: not present
BSD: not present
APM: not present
GPT: not present
Creating new GPT entries in memory.
Command (? for help): n
Partition number (1-128, default 1): 1
First sector (34-234441614, default = 2048) or {+-}size{KMGTP}:
Last sector (2048-234441614, default = 234441614) or {+-}size{KMGTP}: +256M
Current type is 8300 (Linux filesystem)
Hex code or GUID (L to show codes, Enter = 8300): ef00
Changed type of partition to 'EFI system partition'
Partition number (2-128, default 2): 2
First sector (34-234441614, default = 526336) or {+-}size{KMGTP}:
Last sector (526336-234441614, default = 234441614) or {+-}size{KMGTP}:
Changed type of partition to 'Linux filesystem'
Command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): y
OK; writing new GUID partition table (GPT) to /dev/sde.
The operation has completed successfully.
root@zeus-H370M-DS3H:/home/zeus# mkfs.vfat /dev/sde1
mkfs.fat 4.1 (2017-01-24)
root@zeus-H370M-DS3H:/home/zeus# mkfs.ext4 /dev/sde2
mke2fs 1.45.6 (20-Mar-2020)
Creating filesystem with 29239409 4k blocks and 7315456 inodes
Filesystem UUID: 1df05227-02f4-497a-b9e7-f8e4414bf339
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: done
Creating journal (131072 blocks): done
Writing superblocks and filesystem accounting information: done
What it looks like after it is done.
root@zeus-H370M-DS3H:/home/zeus# fdisk -l /dev/sde
Disk model: 2115
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: B0FAEF78-76E3-45DD-8173-518EC01E3889
Device Start End Sectors Size Type
/dev/sde1 2048 526335 524288 256M EFI System
/dev/sde2 526336 234441614 233915279 111.5G Linux filesystem
To copy the files you make the mount point needed.
root@zeus-H370M-DS3H:/home/zeus# mkdir /tmp/ssdboot
root@zeus-H370M-DS3H:/home/zeus# mkdir /tmp/ssdroot
root@zeus-H370M-DS3H:/home/zeus# mount /dev/sde2 /tmp/ssdroot
root@zeus-H370M-DS3H:/home/zeus# mount /dev/sde1 /tmp/ssdboot
For the / (root) copying you need to change the ip to the Pi you have.
root@zeus-H370M-DS3H:/home/zeus# rsync -ahPHAXx --delete --exclude={/dev/*,/proc/*,/sys/*,/tmp/*,/run/*,/mnt/*,/media/*,/lost+found} root@192.168.0.111:/ /tmp/ssdroot/
For the /boot copying you need to change the ip to the Pi you have.
root@zeus-H370M-DS3H:/home/zeus# rsync -ahPHAXx --delete root@192.168.0.111:/boot/* /tmp/ssdboot/
If all seems to have copied over now to changing the UUIDs.
root@zeus-H370M-DS3H:/home/zeus# blkid | grep sde
/dev/sde1: SEC_TYPE="msdos" UUID="EF07-CF76" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="582ecdd1-53dd-4e6c-bedd-6fc4c6e5afbf"
/dev/sde2: UUID="1df05227-02f4-497a-b9e7-f8e4414bf339" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Linux filesystem" PARTUUID="6fc53fb7-324c-466e-b872-79eca8a22d4b"
Added the long PARTUUIDs in the correct places and shutdown the pi and booted. It was way
to faster for me this time, nothing about the GPT flashed or anything as it was GPT drive used.
root@zeus-H370M-DS3H:/home/zeus# nano /tmp/ssdboot/cmdline.txt
root@buster-raspi:~# cat /boot/cmdline.txt
console=tty0 console=ttyS1,115200 root=PARTUUID=6fc53fb7-324c-466e-b872-79eca8a22d4b rw elevator=deadline fsck.repair=yes net.ifnames=0 rootwait
root@zeus-H370M-DS3H:/home/zeus# nano /tmp/ssdroot/etc/fstab
root@buster-raspi:~# cat /etc/fstab
The root file system has fs_passno=1 as per fstab(5) for automatic fsck.
#LABEL=RASPIROOT / ext4 rw 0 1
PARTUUID=6fc53fb7-324c-466e-b872-79eca8a22d4b / ext4 rw 0 1
All other file systems have fs_passno=2 as per fstab(5) for automatic fsck.
#LABEL=RASPIFIRM /boot/firmware vfat rw 0 2
PARTUUID=582ecdd1-53dd-4e6c-bedd-6fc4c6e5afbf /boot vfat rw 0 2
the /proc filesytem
proc /proc proc defaults 0 0
Use MBR drive for anything less that a Pi 4 or 400 as I think those are the only ones for GPT, I know for certain it works flawlessly for me to clone my SSD to another and boot.
