15
I followed this tutorial to set up my Bluetooth dongle and get it running. I have the same Bluetooth dongle that is in the tutorial, yet I can not seem to get it to work. I get to step "C" and then I run into problems. Here is some commands I ran to diagnose the problem:
$ hcitool scan
Device is not available: No such device
$ lsusb
Bus 001 Device 009: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
$ hciconfig dev
hci0:   Type: BR/EDR  Bus: USB
        BD Address: 00:1B:10:00:2A:EC  ACL MTU: 1017:8  SCO MTU: 64:0
        DOWN
        RX bytes:1355 acl:0 sco:0 events:49 errors:0
        TX bytes:204 acl:0 sco:0 commands:48 errors:0
$ hciconfig -a
        DOWN
        Features: 0xff 0xff 0x8d 0xfe 0x9b 0xf9 0x00 0x80
        Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
        Link policy:
        Link mode: SLAVE ACCEPT
$ hcitool dev
Devices:
$ sudo hciconfig hci0 piscan
Can't set scan mode on hci0: Network is down (100)
$ sudo hciconfig hci0 reset
Can't init device hci0: Operation not supported (95)
$ /etc/init.d/bluetooth status
[ ok ] bluetooth is running.
$ sudo bluez-simple-agent
  File "/usr/bin/bluez-simple-agent", line 104, in <module>
    path = manager.DefaultAdapter()
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.bluez.Error.NoSuchAdapter: No such adapter
Any suggestions? Power isn't the issue since I'm running the dongle from a powered USB hub.
I do not want solutions that tell me to downgrade my software. That is not a solution, that is a workaround.
syb0rg
  • 8,178
  • 38
Late answer, but recently experienced it. I noticed the interface is down. Yours is down too.
Running sudo hciconfig hci0 up on an updated firmware solved my problem. Not sure how that happened, as the people from this raspberrypi.org thread insists on downgrading.
Aloha
  • 7,176
  • 29
  • 52
-2
Check my answer in the following thread: http://www.raspberrypi.org/forum/viewtopic.php?t=63418&p=469478
I had the same issue with the same dongle and been able to solve it downgrading the RPi kernel (raspbian).
Cheers,
Olivier
Belokan
