It also says failed to start "enable compressed swap in memory using zram".
Any ideas why my system keeps getting corrupted?
Sorry - ideally any ideas how I can repair/restore?!
Thanks
daneee
  • 71
Your question lacks detail, but two possibilities come to mind:
  1. You have made ill-advised changes to various configuration files and/or your system configuration, or
  2. Your SD card is failing.
If it's # 1, you should re-install your OS, and start over.
If it's not - if you haven't made changes, then you could check & repair the filesystem using fsck - here's one procedure for that.
If fsck finds nothing, there are some other things to try, but it would be best to have a bit more information first.
Finally, and for the longer term: Get (and keep) a spare SD card, and maintain backups of your system.
Seamus
  • 23,558
  • 83
