I've been building a tank robot for a while now and in these days I'm struggling with some issues related to insufficient current in my configuration. For instance, some sensors stop working after a while. Could you help me sort it out? At moment I'm powering my rpi4 with a DYM UPS UPS Shield which should provide me of 5V and 2.2 A, I've also tried with a Chinese power adapter which should provide up to 3A ( I explicitly want to mention I bought it from aliexpress since I don't believe I'm getting 3A out of it) with the same results. I've bought a usb multimeter to check how much A my rpi absorbs and it should arrive somewhen by the end of this week, meanwhile I was hoping you could have given me some insight.
I don't think it's relevant but the program I wrote, to control the robot, is built on top of cross-compiled Qt 5.15, openCV 4 and raspiCam lib.
My only concern about the schema is that rpi GND which goes to GND 18650 batteries that power the motors (the 2 DC motors and the servo)
At moment I'm using a normal 1080p cam, I was using noIR camera before with 2 IR Leds but the outcome was odd, after few seconds every sensors stopped working and eventually rpi glitched forcing me to reboot it. I would like to find a solution to use the noIR camera with night vision btw..
I'm attaching some photos of my little 'Hope' and its configuration.
Tank 1
Tank 2
Wiring
There's a little mistake in the diagram, one of then pin of the H-Bridge is connected wrongly to a gnd pin of the rpi, don't take care of that, it doesn't reflect the real configuration which is fine
I think i've found what's wrong with this setup and is that the 8V ground coming from the 2 18650 batteries in series arrive directly to the i2c multiplexer power line and i believe this is the main cause of my issues. I don't know what i should do to fix it though..
Edit 1: Summarizing, the 3.3v power pin of rpi powers the i2c multiplexer with all the connected sensors, 3 VL53L1-X, a MPU6050, a HMC5883L and a PCA9685. The servo motor and the H-Bridge are powered trough another battery pack consisting of 2 18650 in series whose ground is connected to rpi. Thus rpi has 3 GND tied up together mainly the fan, the i2c multiplexer and the ground from battery pack in series ( plus the ground from the battery shield trough the usb c connector).
Edit 2: Referring to this post it seems i might haver encountered the same kind of issue..
Manfredi6
