I have been developing projects with Raspberry Pi 4. For the current project I am running a NextCloudPi server on it. I am able to access the server using my Internal IP. I want to access it using a public domain name or in other words through open Internet. My ISP does not allow port forwarding and static IP.
I tried Zerotier, which creates a VPN and I can access the CloudServer through the static IP assigned under VPN but the transfer speeds are really slow. Another issue is that I need to install it on all the devices through which I am going to access the CloudServer and ofcourse on the RPi4 itself.
Is there any other option that you guys probably have to access RPi4(Basically IOT devices) through Internet? Any suggestion would be greatly appreciated.
ip addr output
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether dc:a6:32:6a:82:e4 brd ff:ff:ff:ff:ff:ff inet 192.168.1.35/24 brd 192.168.1.255 scope global dynamic noprefixroute eth0 valid_lft 85963sec preferred_lft 75163sec inet6 fe80::f6e0:36ba:532f:10e9/64 scope link valid_lft forever preferred_lft forever
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether dc:a6:32:6a:82:e5 brd ff:ff:ff:ff:ff:ff
I have finally resolved the issue. I have used ngork to create virtual tunnel. I tried to use ngork earlier but was unable as I was running the service on port 80. When I ran the nrogk http service on port 443, I was able to access the NextCloud server using the domain name shown on the ssh terminal. NextCloud uses port 80 for http and 443 for https. I am really not sure why I was not able to access the NextCloud on port 80. This may help if someone is stuck in the similar problem. The problem with ngork is, once the raspberry pi is restarted you will have to restart the ngork service as well and of course the domain address will also be changed. Though my use case don't have any problem with it.
**Full disclosure: I am the founder of SocketXP.
If you want to remotely access your Raspberry Pi behind NAT firewall from anywhere, you can use SocketXP IoT Remote Access solution. You can SSH,VNC or RDP into your Raspberry Pi remotely over the internet. SocketXP also provides a public web-url to remotely access the web service running in your private Raspberry Pi device. It is free to use.
SocketXP IoT Remote Access Solution
Follow the instructions below to setup remote access to your Raspberry Pi via SSH.
Step#1: Download and Install:SocketXP IoT Agent
Download and install SocketXP IoT agent on your IoT or Raspberry Pi device.
Step#2: Login
Sign up here to get your AuthToken. SocketXP has a free plan to try without any strings attached.
Get your authtoken and register your device using the following command:
$ socketxp login <your-authtoken-goes-here>
Step#3: Connect and Access
Next connect your Raspberry Pi or IoT Device to SocketXP Cloud Gateway.
$ socketxp connect tcp://127.0.0.1:22
Connected to SocketXP Cloud Gateway. Access the TCP service securely using the SocketXP agent in IoT Slave Mode.
Now go to SocketXP web portal, go to the devices section, click the terminal icon next to your device, use your SSH login password to SSH into your device.
Public Web URL for any web service
For example, to remotely access a web service (like NextCloudPi) running on your localhost network (say, port 8080) over the internet, execute the below command. The command creates a secure HTTP tunnel to your localhost web service.
$ socketxp connect http://localhost:8080
Connected to SocketXP Cloud Gateway. Public URL -> https://test-user-a29dfe42e3.socketxp.com
After you have successfully created the HTTP tunnel, use the public URL provided by SocketXP ( https://test-user-a29dfe42e3.socketxp.com ) to access your localhost web service (like NextCloudPi) from anywhere in the world.
You can also SSH connect to your Raspberry Pi using PuTTY or Filezilla as explained below.
Step #4: SSH access to Raspberry Pi using PuTTY or Filezilla
Download and install SocketXP agent on your laptop or PC(windows/mac/linux).
$ socketxp.exe connect tcp://localhost:3000 --iot-slave --peer-device-id <device-id> --peer-device-port 22 --authtoken <auth token>
Listening for TCP connections at: Local URL -> tcp://localhost:3000 Accessing the IoT device from your laptop
Now open up PuTTY and connect to "localhost" and port "3000". When prompted provide your SSH login/password. You'll be placed in your Raspberry Pi Shell Prompt.
You can find more instructions on how to setup remote access to your Raspberry Pi behind NAT router or Firewall over the internet using SocketXP here.
