I've installed Volumio v2.8.61 on a new mSD card. After making all setting, I checked the /boot folder - it's almost full (95%)! Therefore it's not possible to maka an upgrade. What's wrong?
The outputs below.
Many thanks!
Thomas
volumio@volumio:/boot$ df -h
Filesystem                     Size  Used Avail Use% Mounted on
/dev/mmcblk0p2                 2.2G  811M  1.3G  39% /imgpart
/dev/loop0                     347M  347M     0 100% /static
overlay                         13G  383M   12G   4% /
devtmpfs                       471M     0  471M   0% /dev
tmpfs                          485M  1.6M  484M   1% /dev/shm
tmpfs                          485M  4.7M  481M   1% /run
tmpfs                          5.0M  4.0K  5.0M   1% /run/lock
tmpfs                          485M     0  485M   0% /sys/fs/cgroup
tmpfs                          485M   28K  485M   1% /tmp
tmpfs                          485M     0  485M   0% /var/spool/cups
tmpfs                           20M  208K   20M   2% /var/log
tmpfs                          485M     0  485M   0% /var/spool/cups/tmp
/dev/mmcblk0p1                  61M   57M  3.4M  95% /boot
STORAGE:/tank/Music/POP        6.7T  4.3T  2.5T  64% /mnt/NAS/1-POP
STORAGE:/tank/Music/CLASSICAL  6.7T  4.3T  2.5T  64% /mnt/NAS/3-CLASSICAL
STORAGE:/tank/Music/JAZZ       6.7T  4.3T  2.5T  64% /mnt/NAS/2-JAZZ
tmpfs                           97M     0   97M   0% /run/user/1000
> volumio@volumio:/boot$ ls -la total 57563 drwxrwxrwx 4 root root
> 3072 Jan 1 1970 . drwxrwxrwx 1 root root 4096 Jan 1 1970 .. > -rw-rw-rw- 1 root root 41 Dec 22 14:46 .firmware_revision > -rw-rw-rw- 1 root root 41 Dec 22 14:46 .firmware_revision_kernel drwxrwxrwx 2 root root 512 Jan 6 10:13 System Volume Information > -rw-rw-rw- 1 root root 24246 Dec 22 14:46 bcm2708-rpi-b-plus.dtb > -rw-rw-rw- 1 root root 23983 Dec 22 14:46 bcm2708-rpi-b.dtb > -rw-rw-rw- 1 root root 23764 Dec 22 14:46 bcm2708-rpi-cm.dtb > -rw-rw-rw- 1 root root 24424 Dec 22 14:46 bcm2708-rpi-zero-w.dtb > -rw-rw-rw- 1 root root 23688 Dec 22 14:46 bcm2708-rpi-zero.dtb > -rw-rw-rw- 1 root root 25310 Dec 22 14:46 bcm2709-rpi-2-b.dtb > -rw-rw-rw- 1 root root 25459 Dec 22 14:46 bcm2710-rpi-2-b.dtb > -rw-rw-rw- 1 root root 27119 Dec 22 14:46 bcm2710-rpi-3-b-plus.dtb > -rw-rw-rw- 1 root root 26500 Dec 22 14:46 bcm2710-rpi-3-b.dtb > -rw-rw-rw- 1 root root 25314 Dec 22 14:46 bcm2710-rpi-cm3.dtb > -rw-rw-rw- 1 root root 41108 Dec 22 14:46 bcm2711-rpi-4-b.dtb > -rw-rw-rw- 1 root root 52360 Dec 22 14:46 bootcode.bin > -rw-rw-rw- 1 root root 399 Dec 22 14:47 cmdline.txt > -rw-rw-rw- 1 root root 169 Dec 22 14:47 config.txt > -rw-rw-rw- 1 root root 7272 Dec 22 14:46 fixup.dat > -rw-rw-rw- 1 root root 5398 Dec 22 14:46 fixup4.dat > -rw-rw-rw- 1 root root 3151 Dec 22 14:46 fixup4cd.dat > -rw-rw-rw- 1 root root 8417 Dec 22 14:46 fixup4db.dat > -rw-rw-rw- 1 root root 8413 Dec 22 14:46 fixup4x.dat > -rw-rw-rw- 1 root root 3151 Dec 22 14:46 fixup_cd.dat > -rw-rw-rw- 1 root root 10261 Dec 22 14:46 fixup_db.dat > -rw-rw-rw- 1 root root 10263 Dec 22 14:46 fixup_x.dat > -rw-rw-rw- 1 root root 5158072 Dec 22 14:46 kernel.img > -rw-rw-rw- 1 root root 5466824 Dec 22 14:46 kernel7.img > -rw-rw-rw- 1 root root 5801056 Dec 22 14:46 kernel7l.img drwxrwxrwx 2 root root 16384 Aug 5 17:46 overlays > -rw-rw-rw- 1 root root 2976416 Dec 22 14:46 start.elf > -rw-rw-rw- 1 root root 2252288 Dec 22 14:46 start4.elf > -rw-rw-rw- 1 root root 799836 Dec 22 14:46 start4cd.elf > -rw-rw-rw- 1 root root 3743076 Dec 22 14:46 start4db.elf > -rw-rw-rw- 1 root root 3011076 Dec 22 14:46 start4x.elf > -rw-rw-rw- 1 root root 799836 Dec 22 14:46 start_cd.elf > -rw-rw-rw- 1 root root 4814916 Dec 22 14:46 start_db.elf > -rw-rw-rw- 1 root root 3734692 Dec 22 14:46 start_x.elf > -rw-rw-rw- 1 root root 90 Dec 22 13:40 userconfig.txt > -rw-rw-rw- 1 root root 19946350 Dec 22 14:53 volumio.initrd
