I'm on a raspberry pi 4b
/home/pi# uname -r
5.4.79-v7l+
and trying to set
/sbin/ethtool -s eth0 speed 100 duplex full
The simple reason for that is because it does not work with autoneg / full speed.
Years ago I would have set that in /etc/network/interfaces but from what I googled the last hours that is depreciated. Additionally my pi would not if I do that. To my mind crontab is not a great solution; additionally I want to set eth0 as the primary connection - needed at boot. Where can put that setting ideally?
Thanks
Marc
  • 78
Ok, I found a solution. I did set up a service. First the script:
cat /etc/network/eth0speed.sh
#!/bin/sh
/sbin/ethtool --change eth0 advertise 0x008
Set the execution rights to ugo+x. Then the service:
etc/systemd/system# cat ethernet-settings.service
[Unit]
Description = Set ethernet speed to max 100mbps
[Service]
Type=oneshot
ExecStart=/etc/network/eth0speed.sh
[Install]
WantedBy=network-pre.target
Enable the service:
systemctl enable ethernet-settings.service
Marc
  • 78
You would be better to fix the problem.
If you decide to continue try:-
sudo ethtool -s eth0 autoneg off
sudo ethtool -s eth0 speed 1000
AFAIK the setting then persists. (I once did this, and had some difficulty restoring autoneg.)
See https://raspberrypi.stackexchange.com/a/116687/8697
You can also add it to the crontab of root. I admit it is a hack:
@reboot sleep 15 && /sbin/ethtool -s eth0 speed 100 duplex full autoneg on
Marc
  • 78
