My Raspberry Pi appears to boot but there is no HDMI output.
I’ve tried various troubleshooting steps but with no success.
Before I go down the route of buying another Pi I was wondering if there’s an OS image out there which would install with SSH (or VNC) enabled and which I could configure to connect to my Wi-fi automatically after installation ?
just put an empty file named ssh in the boot folder and ssh will be automatically enabled
Bra1n
  • 1,261
For this, you will need access to your router:
  1. Flash a normal RaspiOS 32-bit installation to the SD card.
  2. Plug the drive into a computer and add a file named ssh or ssh.txt or SSH.txt (the file can be empty it doesn't matter) to the BOOT drive.
  3. If you want a WiFi connection create another file wpa_supplicant.conf
    country=GB
    update_config=1
    network={
            ssid="Your WiFi SSID goes here"
            psk="Your WiFi password goes here"
    Obviously change the SSID and password to your values. Change Country=GB to your local value.
    Or Connect the Pi to your router with an ethernet cable.
  4. Power it on.
  5. On your routers page search for the Pi and note down the IP address.
    Now on linux type: ssh pi@youradress. Or since the RPi is running mDNS try ssh pi@raspberrypi.local
    On Windows download PuTTY and connect to pi@192.168.xxx.xxx or pi@raspberrypi.local
Dougie
  • 5,381
  • 22
  • 30
