I just got raspbian installed on my SD card and am trying to get my Pi on my network. It's protected with WPA2 Personal.
I opened up the gui network connect and added a new network with the proper SSID, security and password. However, the Pi won't connect. All I'm getting as the status is "Scanning" and the last message being "WPS-AP-AVAILABLE-AUTH".
nopcorn
  • 111
Try adding the following to your network block in /etc/wpa_supplicant/wpa_supplicant.conf
scan_ssid=1
GUI does not add it for hidden networks. After verifying all my other settings and still not connecting, I added this line, did a sudo ifdown wlan0 then sudo ifup wlan0 and it connected and got an IP.
cstanke
Try ditching the gui and try via command line http://www.howtogeek.com/167425/how-to-setup-wi-fi-on-your-raspberry-pi-via-the-command-line/
The simpliest way I know is to set up WiFi via command line, in other words not GUI. This is how I have done it and it's working flawlessly:
Make sure /etc/network/interfaces contain the following:
$sudo nano /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
pre-up wpa_supplicant -B w -D wext -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
post-down killall -q wpa_supplicant
iface default inet dhcp
Edit the following file:
$sudo more /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="YOURSSID"
psk="YOURPASSWORD"
# Protocol type can be: RSN (for WP2) and WPA (for WPA1)
proto=WPA
# Key management type can be: WPA-PSK or WPA-EAP (Pre-Shared or Enterprise)
key_mgmt=WPA-PSK
# Pairwise can be CCMP or TKIP (for WPA2 or WPA1)
pairwise=TKIP
#Authorization option should be OPEN for both WPA1/WPA2 (in less commonly used are SHARED and LEAP)
auth_alg=OPEN
I have also found out that some WiFi-dongles go into sleep-mode after about 6 hours. To that I found the following solution:
Edit the file:
$sudo nano /etc/modprobe.d/8192cu.conf
# Disable power saving
options 8192cu rtw_power_mgnt=0 rtw_enusbss=1 rtw_ips_mode=1
Diego
  • 1,259
