I have modified my apthist script to show only user installed packages.
#!/bin/bash
#Print apt-get history EXCEPT for upgrades
# 2017-08-06
# 2020-10-07 Include packages installed by packagekit
# 2020-12-04 delete lines containing 'apt upgrade' and preceding line
for logf in $(ls /var/log/apt/history.log..gz | sort -rV) ;
do zcat $logf | grep -E -A 1 "Start-Date:|Commandline:" | sed -e '/Requested-By:/d' ; done
| tac | sed -e '/^--/d' -e '/apt .upgrade/{N;d;}' | tac
Include most recent
grep -E -A 1 "Start-Date:|Commandline:" /var/log/apt/history.log | sed -e '/Requested-By:/d'
| tac | sed -e '/^--/d' -e '/apt .*upgrade/{N;d;}' | tac
- Below is a script I use to list apt history. This is still handy if you are interested in upgrades.
#!/bin/bash
for logf in $(ls /var/log/apt/history.log.*.gz | sort -rV) ; do zcat $logf | grep -E -A 1 "Start-Date:|Commandline:" | sed -e '/Requested-By:/d' ; done
# Include most recent
This produces a more manageable list which is easily edited to remove the many "apt upgrade' etc and leave a simple list.
There are some limitations;
- only the last 12 months are shown (because the logs are rotated
monthly and only the 12 most recent are kept) but this can be
extended by editing
/etc/logrotate.d/apt
The following script uses the history produced by the above and filters to show User history, excluding updates.
#! /bin/sh
# delete lines containing 'apt upgrade' and preceding line
# useful for finding apt history EXCEPT for upgrades
# run on output of apthist.sh
cat $1 | tac | sed -e '/^--/d' -e '/apt .*upgrade/{N;d;}' | tac
You SHOULD do regular backups.
Backup image of SD Card
produces a small customised image that can be used to create new SD Cards.
This is a file based backup, so should be immune to SD Card problems.
You may also be interested in the following. I use this to synchronise my latest updated OS to a SD Card which contains an installed Raspberry Pi OS. You could use this to populate a freshly installed OS. This does not copy /home, but you could uncomment the line to include it.
#!/bin/bash
# script to synchronise Pi files to SD Card
# 2019-08-12
# 2020-09-30
# 2020-10-23 copy /home/*
This script synchronises necessary files from running OS on Pi to SD Card
SD Card (already formatted with partitions containing OS) in SD Card reader on Pi
NOTE does not copy cmdline.txt or /etc/fstab
NOTE does not copy /home/*
NOTE file rsync EXCLUDE_FILE is required
use 'rsync-dup-exclude.txt' as we WANT logs & .bash_history to be copied
EXCLUDE_FILE='rsync-dup-exclude.txt'
echo $EXCLUDE_FILE
BOOT_MOUNT='/mnt/SDA1'
ROOT_MOUNT='/mnt/SDA2'
Check/create Mount Points
if [ ! -e $BOOT_MOUNT ]; then
mkdir $BOOT_MOUNT
fi
if [ ! -e $ROOT_MOUNT ]; then
mkdir $ROOT_MOUNT
fi
echo $BOOT_MOUNT $ROOT_MOUNT
Mount Partitions
if ! $(mountpoint -q $BOOT_MOUNT); then
mount /dev/sda1 $BOOT_MOUNT # mount partition containing boot files
fi
if ! $(mountpoint -q $ROOT_MOUNT); then
mount /dev/sda2 $ROOT_MOUNT # mount root partition containing OS files
fi
if $(mountpoint -q $BOOT_MOUNT) && $(mountpoint -q $ROOT_MOUNT); then
echo "Synchronise boot files to SD Card"
rsync -a --delete-during --exclude='cmdline.txt' --exclude='/SD?' --exclude='/SD??' /boot/ $BOOT_MOUNT/
echo "Synchronise OS files to SD Card"
$ROOT_MOUNT/
rsync -axH --progress --delete-during --exclude='/etc/fstab' --exclude='/home/*' --exclude='WolframEngine' --exclude='scratch2' --exclude-from=$EXCLUDE_FILE / $ROOT_MOUNT/
rsync -axH --progress --delete-during --exclude='/etc/fstab' --exclude='WolframEngine' --exclude='scratch2' --exclude-from=$EXCLUDE_FILE / $ROOT_MOUNT/
umount $BOOT_MOUNT
umount $ROOT_MOUNT
else
echo "Backup Card not available or not writable"
fi
This needs to file rsync-dup-exclude.txt to exclude unnecessary files.
/proc/*
/sys/*
/dev/*
/boot/*
/tmp/*
/run/*
/mnt/*/*
/var/cache/*
/boot/cmdline.txt
/etc/fstab
.Trashes
._.Trashes
.fseventsd
.Spotlight-V100
.DS_Store
.AppleDesktop
.AppleDB
Network Trash Folder
Temporary Items
.cache
/etc/fake-hwclock.data
/var/lib/rpimonitor/stat/
/etc/hostname
/etc/hosts
