I'm trying to setup my new Wifi dongle I've bought from ModMyPi.
Its working for DHCP but when I try to make it a static IP, I get this error when restarting it:
wpa-roam can only be used with the manual inet METHOD
Here is my /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.1.3
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.254
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.2
network 192.168.1.0
Here is my wpa_supplicant.conf:
update_config=1
network={
    ssid="My-Wifi"
    psk="my_password"
I don't know what else to do to get it to use 192.168.1.2 as its static IP wirelessly. Help?
If it helps, I have a BTHomeHub3 with a WPA & WPA2 compatible key and my SSID is visible.
UPDATE I would like my configuration to support multiple wifi networks setup so that when I move to and from University and Home, My Raspberry Pi can just work wirelessly.
My files are currently like so:
/etc/network/interfaces: http://pastebin.com/HeP8kgBR /etc/wpa_supplicant/wpa_supplicant.conf: http://pastebin.com/RaFkEAx6
UPDATE When I run sudo ifup wlan0 now I am getting this error:
Failed to connect to wpa_supplicant - wpa_ctrl_open: No such file or directory
Jamesking56
  • 273
In the end I got it working as I wanted, here is what I did.
I restored the original /etc/network/interfaces file and /etc/wpa_supplicant/wpa_supplicant.conf to make sure those aren't an issue.
I then ran startx to launch into the GUI and used WiFi Config to scan for my network and set it up. When setting it up, I specified the ID at the bottom of the setup window and called it home.
I then edited /etc/network/interfaces to add iface home inet static and defined my static IP information.
After a reboot, it worked perfectly!
Thanks everybody for your help, the GUI was the best way in the end.
Jamesking56
  • 273
In /etc/network/interfaces Change iface wlan0 inet static to iface wlan0 inet manual
Now put in a new line:
iface somenamehere inet static
Then cut the wlan0 static IP info(not the wpa-roam part) and paste it underneath. Your interfaces file should now look like:
auto lo
address 192.168.1.3
network 192.168.1.0
allow-hotplug wlan0
address 192.168.1.2
network 192.168.1.0
Note: I leave out network and broadcast from my static IP configuration and it always works fine.
Now in wpa_supplicant.conf add the line
id_str="somenamehere"
In the network setting part. It should now look like:
update_config=1
network={
    ssid="My-Wifi"
    psk="my_password"
Change somenamehere to anything you like.
Look at my answer here for more info on setting up wpa_supplicant.conf with multiple networks
11chubby11
  • 4,872
  • 26
If you only have one network in wpa_supplicant.conf, rather than using wpa-roam, use wpa-conf as this will allow you to use static IP addresses.
Lawrence
  • 2,692
