I have uninstalled BlueZ from my raspberry pi.
sudo apt-get --purge remove bluez
Then, I reinstalled it using this tutorial:
wget http://www.kernel.org/pub/linux/bluetooth/bluez-5.47.tar.xz
tar -xvf bluez-5.47.tar.xz
cd bluez-5.47/
./configure --enable-mesh --prefix=/usr --mandir=/usr/share/man --sysconfdir=/etc --localstatedir=/var
make
sudo make install
sudo ln -sf /usr/libexec/bluetooth/bluetoothd /usr/lib/bluetooth/bluetoothd
sudo systemctl daemon-reload
Then, I did bluetoothd -v as the tuto was suggesting and it told me "command not found". I went on by adding /usr/lib/bluetooth/ to PATH in my ~/.bashrc.
Then, bluetoothd -v gives me 5.47.
But sudo systemctl status bluetooth gives me:
● bluetooth.service - Bluetooth service
   Loaded: loaded (/etc/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: inactive (dead)
     Docs: man:bluetoothd(8)
I tried sudo systemctl start bluetooth, sudo systemctl enable bluetooth.service and none of that worked. (cf https://askubuntu.com/questions/779911/bluetooth-status-inactive-dead).
What makes the bluetooth service inactive? I also remarked that my /etc/bluetooth/ folder does not exist anymore since I reinstalled BlueZ. Why is that?
Specs:
  • Raspberry Pi 3 Model B Rev 1.2
  • BlueZ v 5.47
vvvvv
  • 299
I did:
sudo modprobe btusb  # add the btusb module to the kernel
sudo systemctl start bluetooth.service
And it works!
$ sudo systemctl status bluetooth.service
   Active: active (running) since Fri 2020-11-06 21:38:45 CET; 6s ago
 Main PID: 2434 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/bluetooth.service
           └─2434 /usr/lib/bluetooth/bluetoothd
I found the answer here: https://stackoverflow.com/a/44079184/5446749
vvvvv
  • 299
I assume you are using a Raspberry Pi OS based on Buster. It is curious that systemd does not give you any output what's going on with the bluetooth.service. The status should at least contain additional lines why it fails to start, something similar to this with some red lines:
Nov 02 12:00:48 raspberrypi systemd[1]: Starting Bluetooth service...
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Bluetooth daemon 5.50
Nov 02 12:00:48 raspberrypi systemd[1]: Started Bluetooth service.
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Starting SDP server
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Bluetooth management interface 1.14 initialized
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Sap driver initialization failed.
Nov 02 12:00:48 raspberrypi bluetoothd[714]: sap-server: Operation not permitted (1)
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Endpoint registered: sender=:1.22 path=/org/bluez/hci0/A2DP/SBC/Source/1
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Endpoint registered: sender=:1.22 path=/org/bluez/hci0/A2DP/SBC/Source/2
Nov 02 12:00:48 raspberrypi bluetoothd[714]: Failed to set privacy: Rejected (0x0b)
Try this:
rpi ~$ rfkill unblock bluetooth
rpi ~$ sudo systemctl enable bluetooth.service
rpi ~$ sudo systemctl reboot
After login:
rpi ~$ sudo systemctl restart bluetooth.service
rpi ~$ systemctl status bluetooth.service
It may also show you that the service is dead but it should show additional lines why it fails. You can also look at the journal for the bluetooth.service:
rpi ~$ journalctl --boot --unit bluetooth.service
Look at the Unit file what the service is doing:
rpi ~$ systemctl cat bluetooth.service
The default Unit from 2020-08-20-raspios-buster-armhf looks like this:
# /lib/systemd/system/bluetooth.service
[Unit]
Description=Bluetooth service
Documentation=man:bluetoothd(8)
ConditionPathIsDirectory=/sys/class/bluetooth
[Service] Type=dbus BusName=org.bluez ExecStart=/usr/lib/bluetooth/bluetoothd NotifyAccess=main #WatchdogSec=10 #Restart=on-failure CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE LimitNPROC=1 ProtectHome=true ProtectSystem=full
[Install] WantedBy=bluetooth.target Alias=dbus-org.bluez.service
Ingo
  • 42,961
  • 207
If nothing else works, a good idea is to check the configuration file /boot/config.txt. Mine had Bluetooth explicitly disabled—something I did a long time ago when I didn't need Bluetooth, and forgot since then:
# Disable Wi-Fi and Bluetooth
dtoverlay=pi3-disable-wifi
dtoverlay=pi3-disable-bt
Commenting out the last line helped.
Arseni Mourzenko
  • 154
