I have an IoT project that uses the Pi Zero W and at some point want to utilize the compute modules for industrial application. Currently, doing dev I may use a RPi 3/4 to copy files across and run code (mainly b/c its faster than the Zero). However, it is a pretty slow and a painful dev experience. It works and have taken the project quite far with it but I am wanting to improve the enjoyment aspect of it.
Is there a standard practice for stubbing/mocking modules like the RPi.GPIO and Adafruits adafruit-circuitpython-neopixel module. I did run across this GitHub repo for mocking RPI.gpio and will probably use it but wanted to see if there was something I am just missing. Just curious if people would dev against the mock, like the linked repo above, and then only just exclude the local mocked module when transferring to the RPi?
Coming from a software centric background, I am not quite sure how the community really unit tests all aspects of there application? Is there something similar to a mobile IOS/Android simulator...where you can still do all development on the host machine but not be limited to kind of blindly coding and moving them along to the RPi device.
afreeland
  • 101
