OK, This is a little frustrating as I am JUST trying to get the temperature/Humidity readings on my DHT 11 sensor with Raspberry pi 4 and I am unable to do so. Please see below
https://www.electronicwings.com/raspberry-pi/dht11-interfacing-with-raspberry-pi
I get an error asking me to run the same as sudo.
Then after I try to run the program as a sudo user I get the following error repeatedly:
"Failed to get the readin. Try Again"
I even tried changing the sensor to no avail....
There were some posts suggesting a different version as the Adafruit function does not seem support the latest hardware. However there does not seem to be a proper closure to any of the posts. enter image description here I also tried this
https://stackoverflow.com/questions/63232072/cannot-import-name-beaglebone-black-driver-from-adafruit-dht
Any help is appreciated.
Ok So like Dougie suggested I went to the post and downloaded DHT.PY
Reliable temperature/humidity logging with Python and a DHT11
After downloading DHT.Py , I ran the script mentioned in the link above and then when i ran I do not see any error message nor do i see any out put
I also ensured to keep the DHT.Py and the script that i am running in the same folder...(Double checked pins , nothing much to check anyways, there is ground , power and pin 4 (BCM)), SO it is not the circuit or the sensor , so I ma guessing it must be code. I also did sudo pigpiod before I ran all this..
Am i just being plain stupid or is this really an issue ??
The code I ACTUALLY use is raspberrypi.stackexchange.com/a/105549/8697
This doesn't actually output anything and only posts a single MQTT message.
The following simplified code prints a single reading.
#!/usr/bin/env python3
2020-09-27
""" A Program to read the DHTXX temperature/humidity sensors.
REQUIREMENTS
DHT.py    download "module" from http://abyz.me.uk/rpi/pigpio/code/DHT.py
pigpiod running
import sys import pigpio import DHT import time import datetime
Sensor should be set to DHT.DHT11, DHT.DHTXX or DHT.DHTAUTO
sensor = DHT.DHT11
pin = 4 # Data - Pin 7 (BCM 4)
def output_data(timestamp, temperature, humidity): # Sample output Date: 2019-11-17T10:55:08, Temperature: 25°C, Humidity: 72% date = datetime.datetime.fromtimestamp(timestamp).replace(microsecond=0).isoformat() print(u"Date: {:s}, Temperature: {:g}\u00b0C, Humidity: {:g}%".format(date, temperature, humidity))
pi = pigpio.pi() if not pi.connected: exit()
s = DHT.sensor(pi, pin, model = sensor)
tries = 5 # try 5 times if error while tries: try: timestamp, gpio, status, temperature, humidity = s.read() #read DHT device if(status == DHT.DHT_TIMEOUT): # no response from sensor exit() if(status == DHT.DHT_GOOD): output_data(timestamp, temperature, humidity) exit() # Exit after successful read time.sleep(2) tries -=1 except KeyboardInterrupt: break
from pigpio_dht import DHT11, DHT22
gpio = 4 # BCM Numbering
sensor = DHT11(gpio)
#sensor = DHT22(gpio)
result = sensor.read()
print(result)
Even I had the same problem..This worked for me you can also try once. Before running the code enter the commands on the terminal
sudo pigpiod #Start daemon
pigs pud 4 u # Set internal pull up
If pigpio-dht is not installed enter pip3 install pigpio-dht and run the above program
Madhuraank B
