I realize this 2014 blog post showing how to setup sendmail on a Rapsberry Pi is a bit outdated, but, am I stretching too much to expect the following command to work on my new Buster / Raspberry Pi OS?
Here's the part of the instructions I was following:
Save the authinfo file and use makemap to create the binary version. The following command creates a file called “authinfo.db“, using the information you placed into authinfo.
And this command is what I'm trying to do:
# makemap hash /etc/mail/authinfo < /etc/mail/authinfo
All I get is command not found, even if I prefix it with sudo
bkwdesign
  • 103
I think makemap is in package sendmail-bin.
See if it works after
sudo apt install sendmail-bin
Mind you it seems odd that this hasn't already been installed if you are using sendmail.
joan
  • 71,852
  • 76
  • 108
I agree with Dougie's comments.
While sendmail is in the repository I doubt it would work (even if you manage to fight your way through the configuration). (ssmtp is also in the repository and it doesn't work)
I suggest you try msmtp - See https://raspberrypi.stackexchange.com/a/100704/8697
