So there is support for Open GL ES 3.1, but how can I use it on the Raspberry Pi 4? Is there any other way to use the GPU for calculations such as fft and logarithm?
Asked
Active
Viewed 3,701 times
Check for the boot partition. There you can find many overlays. Try using them. And install mesa gl driver. Then you can activate them from raspi-config
Sohan Arafat
- 1,852
- 2
- 12
- 43
You might like to look at Pete Warden's work using Deep Learning for image recognition with the RPi's GPU here. If you want to code using the GPU have a look at QPILib which is an astonishing piece of work building a language to code on to the Rpi's GPU using only C++'s macro language.
QPULib is a programming language and compiler for the Raspberry Pi's Quad Processing Units (QPUs). It is implemented as a C++ library that runs on the Pi's ARM CPU, generating and offloading programs to the QPUs at runtime.
Nick
- 774
- 4
- 16
