Here is the video where it is explained step by step how to prevent U-boot console from interrupting autoboot and sending debug messages on UART. I know links only answers are frowned upon, so here' s a quick breakdown of a solution:
Install the dependencies
sudo apt install git make gcc gcc-aarch64-linux-gnu
Git clone the official u-boot repository. Alternatively you can git clone my fork of repository, where I already have the necessary changes for silent autoboot - but if you need the latest version, then you need to clone the official repository and make changes yourself.
git clone --depth 1 git://git.denx.de/u-boot.git
cd u-boot
Find the raspberry pi config files - they depend on the model, configs/rpi_3_defconfig for Raspberry Pi 3, configs/rpi_4_defconfig for Raspberry Pi 4, and so on.
Add the following lines to the end of the file
CONFIG_BOOTDELAY=-2
CONFIG_SILENT_CONSOLE=y
CONFIG_SYS_DEVICE_NULLDEV=y
CONFIG_SILENT_CONSOLE_UPDATE_ON_SET=y
CONFIG_SILENT_U_BOOT_ONLY=y
The first line removes the boot delay, so autoboot will not be interrupted by messages sent on UART interface. Next four lines enable silent boot, so U-boot will not send any messages on UART itself, because the messages might in turn confuse your device. One more little thing left, set silent boot environmental variable. Change include/configs/rpi.h file
#define CONFIG_EXTRA_ENV_SETTINGS \
"dhcpuboot=usb start; dhcp u-boot.uimg; bootm\0" \
"silent=1\0" \
ENV_DEVICE_SETTINGS \
ENV_DFU_SETTINGS \
ENV_MEM_LAYOUT_SETTINGS \
BOOTENV
Now configure with
make rpi_3_defconfig
# or
make rpi_4_defconfig
from repository main folder and build with
make CROSS_COMPILE=aarch64-linux-gnu-
When build process finishes you will have a u-boot.bin file, which you need to rename and copy to Raspberry Pi SD card (e.g. to /boot/firmware/uboot_rpi_4.bin for a Raspberry Pi 4). Now your Raspberry Pi will not be disturbed by any messages on UART during boot. The UART functionality after boot will not be affected.
UPDATE 10/06/2024
currently u-boot has migrate to the text-based environment. https://docs.u-boot.org/en/latest/usage/environment.html#text-based-environment
below is my patch for disabling UART console for rpi-4
From 3ced0f1608d6ded3d8474ea4a98aec00ae67fe9e Mon Sep 17 00:00:00 2001
Date: Mon, 10 Jun 2024 18:32:25 +0530
Subject: [PATCH] disable uart for u-boot
board/raspberrypi/rpi/rpi.env | 2 ++
configs/rpi_4_defconfig | 5 +++++
2 files changed, 7 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.env b/board/raspberrypi/rpi/rpi.env
index 30228285ed..44a427512c 100644
--- a/board/raspberrypi/rpi/rpi.env
+++ b/board/raspberrypi/rpi/rpi.env
@@ -3,6 +3,8 @@
/* environment for Raspberry Pi boards */
+bootdelay=-2
+silent=1
/* Environment */
stdin=serial,usbkbd
diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig
index 2541b83a3d..a5dc879d6a 100644
--- a/configs/rpi_4_defconfig
+++ b/configs/rpi_4_defconfig
@@ -65,3 +65,8 @@ CONFIG_SYS_WHITE_ON_BLACK=y
CONFIG_VIDEO_BCM2835=y
CONFIG_CONSOLE_SCROLL_LINES=10
CONFIG_PHYS_TO_BUS=y
+CONFIG_BOOTDELAY=-2
+CONFIG_SILENT_CONSOLE=y
+CONFIG_SYS_DEVICE_NULLDEV=y
+CONFIG_SILENT_CONSOLE_UPDATE_ON_SET=y
+CONFIG_SILENT_U_BOOT_ONLY=y
you can apply this patch as recipe or manually modify both files to add changes.
Relevant docs:
