I have a number of SD Cards running Raspberry Pi OS and want to keep these in sync.
It is possible (by many different methods) to create an installable image, which can be used to create copies of SD Cards (I use Backup image of SD Card ).
This works, but is slow and may require some customisation of the target.
I use the following script to synchronises necessary files from running OS on Pi to SD Card in SD Card reader on the Pi.
NOTE the SD Card must be already formatted with partitions containing OS.
This excludes 'cmdline.txt' and '/etc/fstab' - which is ESSENTIAL to ensure the SD Card boots - this, of course assumes the existence of correct matching files on the SD Card.
(You will also note a couple of other exclusions, but these can be removed.)
#!/bin/bash
# script to synchronise Pi files to SD Card
# 2019-08-12
This script synchronises necessary files from running OS on Pi to SD Card
SD Card (already formatted with partitions containing OS) in SD Card reader on Pi
NOTE does not copy cmdline.txt or /etc/fstab
NOTE file rsync EXCLUDE_FILE is required
use 'rsync-dup-exclude.txt' as we WANT logs & .bash_history to be copied
EXCLUDE_FILE='rsync-exclude.txt'
EXCLUDE_FILE='rsync-dup-exclude.txt'
echo $EXCLUDE_FILE BOOT_MOUNT='/mnt/SDA1' ROOT_MOUNT='/mnt/SDA2'
Check/create Mount Points
if [ ! -e $BOOT_MOUNT ]; then mkdir $BOOT_MOUNT fi if [ ! -e $ROOT_MOUNT ]; then mkdir $ROOT_MOUNT fi echo $BOOT_MOUNT $ROOT_MOUNT
Mount Partitions
if ! $(mountpoint -q $BOOT_MOUNT); then mount /dev/sda1 $BOOT_MOUNT # mount partition containing boot files fi if ! $(mountpoint -q $ROOT_MOUNT); then mount /dev/sda2 $ROOT_MOUNT # mount root partition containing OS files fi
if $(mountpoint -q $BOOT_MOUNT) && $(mountpoint -q $ROOT_MOUNT); then echo $BOOT_MOUNT $ROOT_MOUNT echo "Synchronise boot files to SD Card" rsync -a --delete-during --exclude='cmdline.txt' --exclude='/SD?' --exclude='/SD??' /boot/ $BOOT_MOUNT/ echo "Synchronise OS files to SD Card" rsync -axH --progress --delete-during --exclude='/etc/fstab' --exclude='WolframEngine' --exclude='scratch2' --exclude-from=$EXCLUDE_FILE / $ROOT_MOUNT/ umount $BOOT_MOUNT umount $ROOT_MOUNT else echo "Backup Card not available or not writable" fi
NOTE file rsync EXCLUDE_FILE is required either rsync-dup-exclude.txt
/proc/*
/sys/*
/dev/*
/boot/*
/tmp/*
/run/*
/mnt/*/*
/var/cache/*
/boot/cmdline.txt /etc/fstab
.Trashes ._.Trashes .fseventsd .Spotlight-V100 .DS_Store .AppleDesktop .AppleDB Network Trash Folder Temporary Items
.cache /etc/fake-hwclock.data /var/lib/rpimonitor/stat/ /etc/hostname /etc/hosts
OR rsync-exclude.txt
/proc/*
/sys/*
/dev/*
/boot/*
/tmp/*
/run/*
/mnt/*/*
/var/log/*
/var/cache/*
.bash_history .cache /etc/fake-hwclock.data /var/lib/rpimonitor/stat/ /etc/hostname /etc/hosts
