I have the following 128 x 128 OLED display: http://www.lcdwiki.com/zh/1.5inch_OLED_Module_SKU:MC01503 which is driven by a SSD1327 module.
I'm trying to use this with a Pi 4 and the Luma.oled python repository of rm-hull, which supports SSD1327: https://github.com/rm-hull/luma.oled
The installation of the libraries was carried out according the the instructions here: https://github.com/rm-hull/luma.examples
everything installed with no problems. However, whenever I try to use any examples, or run the library from my own code, it always throws an error that it can't find the OLED display. The traceback is as follows:
File "/usr/local/lib/python3.7/dist-packages/smbus2/smbus2.py", line 622, in write_i2c_block_data ioctl(self.fd, I2C_SMBUS, msg)
OSError: [Errno 121] Remote I/O error
However, running i2cdetect shows the device exactly where expected.
I have previously successfully communicated with an ADS1115 ADC converter using I2C from this same Pi, so it shouldn't be a problem with the pins or the Pi itself.
Does anyone have any experience with running this display who could shed some light on why i2cdetect can see the chip, but the python library can't?
