I've got a Pi 4 and went to hook up a couple sensors, the first being a DHT11, it's working fine. The second being a DS18B20, on the 1-wire interface (using the standard GPIO pin 4). The circuit is identical to how I had it on a Pi 3, sensor ground to ground, sensor + to 3.3v, data line to pin 4, with a 4.7k pull-up resistor between the data line and the 3.3v line.
The sensor actually works fine in this configuration, I'm getting good readings from it. The problem I'm having is that when the sensor is connected to the 1-wire interface, the wireless networking will not function.
[   17.128561] brcmfmac: brcmf_escan_timeout: timer expired
[   19.688578] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   19.688790] brcmfmac: brcmf_notify_escan_complete: Scan abort failed
[   22.248590] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   24.808577] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   24.808800] brcmfmac: brcmf_set_wpa_version: set wpa_auth failed (-110)
[   24.808804] brcmfmac: brcmf_cfg80211_connect: wl_set_wpa_version failed (-110)
[   27.448573] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   27.448797] brcmfmac: brcmf_run_escan: error (-110)
[   27.448803] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[   30.968578] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   30.968791] brcmfmac: brcmf_run_escan: error (-110)
[   30.968798] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[   33.136292] Bluetooth: Core ver 2.22
[   33.136338] NET: Registered protocol family 31
[   33.136342] Bluetooth: HCI device and connection manager initialized
[   33.136354] Bluetooth: HCI socket layer initialized
[   33.136361] Bluetooth: L2CAP socket layer initialized
[   33.136380] Bluetooth: SCO socket layer initialized
[   34.488578] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   34.488799] brcmfmac: brcmf_run_escan: error (-110)
[   34.488805] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[   36.640124] Bluetooth: HCI UART driver ver 2.3
[   36.640134] Bluetooth: HCI UART protocol H4 registered
[   36.640177] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   36.640308] Bluetooth: HCI UART protocol Broadcom registered
[   38.008583] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   38.008818] brcmfmac: brcmf_run_escan: error (-110)
[   38.008826] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[   41.528576] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[   41.528803] brcmfmac: brcmf_run_escan: error (-110)
[   41.528811] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
I moved the 1-wire to a different gpio pin thinking that might help, but I'm still getting the same results. My sensors all work, but no WiFi. I've measure the voltages on the data pin, getting ~3.3 as I'd expect. Any ideas on what could be going on?
Thanks in advance.
lane.maxwell
I had this same issue; it turned out to be a weak power supply for the pi4. After using a type-C laptop charger, the issue went away.
ThankYee
  • 126
