I have tried to install the one from apt, but that was really old
So I tried to go to mongo website and download the newest version
but then I get this isse:
The following packages have unmet dependencies:
 mongodb-org-server:arm64 : Depends: libc6:arm64 (>= 2.18) but it is not installable
                            Depends: libcurl3:arm64 (>= 7.16.2) but it is not installable
                            Depends: libgcc1:arm64 (>= 1:4.2) but it is not installable
                            Depends: libssl1.0.0:arm64 (>= 1.0.1) but it is not installable
E: Unable to correct problems, you have held broken packages.
why is this not installable? any suggestion?
tiagodll
You are using Raspbian. This is only built with a 32 bit architecture armhf. I seems you have downloaded MongoDB with the 64 bit architecture arm64. You cannot run 64 bit programs on a 32 bit architecture. You either have to use a 32 bit MongoDB or use a 64 bit operating system. There is a 64 bit Raspberry Pi OS in beta test. You can try to use that.
Ingo
  • 42,961
  • 207
