I am trying to update all of the software on my model b pi.
I have cleared as much space as possible - then did df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       6.0G  5.2G  450M  93% /
devtmpfs        427M     0  427M   0% /dev
tmpfs           432M     0  432M   0% /dev/shm
tmpfs           432M   12M  420M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           432M     0  432M   0% /sys/fs/cgroup
/dev/mmcblk0p6   63M   20M   43M  32% /boot
tmpfs            87M     0   87M   0% /run/user/1000
/dev/mmcblk0p5   30M  398K   28M   2% /media/pi/SETTINGS2
The sudo apt full-upgrade command told me it needed this much space:
After this operation, 223 MB of additional disk space will be used.
But the unpacking process failed with:
Unpacking libreoffice-calc (1:4.3.3-2+rpi4) over (1:4.3.3-2+rpi3) ...
Preparing to unpack .../libreoffice-core_1%3a4.3.3-2+rpi4_armhf.deb ...
Unpacking libreoffice-core (1:4.3.3-2+rpi4) over (1:4.3.3-2+rpi3) ...
dpkg:../../src/unpack.c:123:deb_reassemble: internal error: unexpected exit status 11 from dpkg-split
E: Sub-process /usr/bin/dpkg exited unexpectedly
Or should I change OS to stretch (does that work on model b? I have no legacy software on my pi - clean start would not be a hardship. Very grateful for any ideas.
Dirk
  • 3,749
So I strongly recommend to do it. There are some important reasons to do it, because it isn't worth the effort to fix your installation:
  1. Jessie is deprecated since years and out of any support since 2020-01-01. Its repository is archived.
  2. Seems you have installed NOOBS but only using Raspbian. NOOBS is a waste of storage. As far as I know it needs more than 1 GB of space. Most of us does not use it because it is also error prone.
  3. Just install the Raspberry Pi OS version Buster direct from its image. This will save storage. And yes, it will also run on your RPi 2B.
Ingo
  • 42,961
  • 207
You seem to be running NOOBS (one of the Foundation's worst ideas).
This is NOT upgradable - even a "fresh install" will fail.
Even if you had directly installed Raspbian, the Foundation advice is to do a fresh install of Buster. (It is possible for expert users to upgrade but this actually takes longer than a fresh install. Skipping versions just makes this more difficult.)
Install Raspberry Pi OS using one of the recommended methods
