Setting up Raspberry Pi 4B as a routed access point
Hi guys
I want to set up my Raspberry Pi 4B as a routed access point. Many IoT-devices in the subnetwork 192.168.7.x should connect to my RasPi over an Edimax EW-788Un Wi-Fi dongle (wlan1). The RasPi should connect itself to my home network over onboard Wi-Fi (wlan0). Here a list of the resources I have already considered:
Simultaneously connect to a wifi network and create a wifi AP https://github.com/garyexplains/examples/blob/master/raspberry_pi_router.md https://www.raspberrypi.org/documentation/configuration/wireless/access-point-routed.md
Following those guides, I have apt-get installed the following packages
dnsmasq
hostapd
My files are set up like so:
DHCP
/etc/dhcpcd.conf:
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option interface_mtu
require dhcp_server_identifier
slaac private
interface wlan1
static ip_address=192.168.7.1/24
nohook wpa_supplicant
dnsmasq
/etc/dnsmasq.conf:
interface=wlan1
dhcp-range=192.168.7.100,192.168.7.120,255.255.255.0,24h
domain=wlan
address=/gw.wlan/192.168.7.1
IP-Forwarding
/etc/sysctl.conf:
net.ipv4.ip_forward=1
/etc/iptables.ipv4.nat:
*filter
:INPUT ACCEPT [20652:1431292]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [15820:11346033]
COMMIT
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A POSTROUTING -o wlan0 -j MASQUERADE
COMMIT
hostapd
/etc/hostapd/hostapd.conf:
country_code=CH
interface=wlan1
driver=nl80211
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
ssid=swagsystem
wpa_passphrase=swagsystem
PROBLEM:
Upon start (sudo systemctl start hostapd) of the hostapd service, the following error occurs:
Job for hostapd.service failed because the control process exited with error code.
See "systemctl status hostapd.service" and "journalctl -xe" for details.
Invoking systemctl status hostapd.service yelds:
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2020-06-16 14:16:19 CEST; 924ms ago
Process: 2684 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAIL
(^^ it cut off there at the end)
iwconfig yields:
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"NalasEmpire"
Mode:Managed Frequency:5.5 GHz Access Point: 1C:24:CD:33:35:69
Bit Rate=200 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=70/70 Signal level=-40 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:53 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
wlan1 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:off
wlan1 (my Edimax dongle) was previously tuned in to the same network as wlan0. The setup kind of did something to it, but idk exactly what.
Does anyone see where I went wrong or what could be the problem?
EDIT1:
I switched to using predictable network interfaces (found int
sudo rasp-config). This switched mywlan1to wlx08beac0a717c (idk if that changed sth.)I put in the driver
driver=nl80211back into hostapd (idk if that changed sth.)Made it run by default using
sudo update-rc.d hostapd defaultsI used
sudo hostapd -B /etc/hostapd/hostapd.confto start the daemon. This turned up an Error in the config file after which it is not allow to use less than 8 characters for the WPA passphrase. Changed that and well: it works! At least to the point that a new network now appears in my choice of available wifi-networks.
A new error appeared though:
wlx08beac0a717c: interface state UNINITIALIZED->COUNTRY_UPDATE
Q1: So I know that for the onboard wifi to set the country code you can do it in raspi-config, but how do I do it for the edimax wifi dongle?
Q2: I'm unsure whether to add an /etc/network/interfaces.d/native_wifi.cfg file. As of the moment I don't have it, but what is its use? Do I need to set the Edimax interface to static and provide a subnetmask? It appears in some guides, but not in all.
