There seem to be jumpers to connect POE into the RaspberryPi. I have a case with two little fans which are meant to connect to the GPIO. I think they could be connected to the pins of the POE but I would like to know if this is likely to cause problems. I don't want to use POE.
POE voltage range is 37 to 57 V. Unless your fans support such high voltages, there's no point in connecting them there.
If you don't connect your Pi to a POE source, then there will be no substantial voltage on the POE header, and the fans will also not work.
- 28,277
- 6
- 54
- 147
The PoE "implementation" on RPi (3B+ & 4B) is a bit of a sham IMHO. I say this because the necessary hardware is not included.
As a practical matter, wrt powering your fans you would need to do a fair amount of work to use the power. POE is governed by a rather complex group of standards and specifications. Delivery of power to the RPi's terminals would need to be negotiated with the upstream POE provider. Strictly as a personal viewpoint, requiring a "HAT" to use POE on a Raspberry Pi strikes me as some type of a joke - but personal viewpoints aside, in your case I'd opine there are better and easier (certainly less expensive) methods to power a fan.
If you want a more practical way to power your fan, this question has been asked and answered here, and in a variety of blog posts - for example.
If this doesn't fully address your question, please let us know.
- 23,558
- 5
- 42
- 83
