9
Recently, I bought a USB3 WiFi adapter with the RTL8812BU chip (Supports Linux).
I have spent 5 hours so far trying to install the Linux driver for the chip on my Raspberry Pi 4.
Apparently, I am not able to do this on my own so I hope that you guys can help me.
Here is what I have done so far:
Install build tools:
sudo apt install build-essential bc git wget libssl-dev bison flex dkms
Get kernel source code
cd /usr/src
sudo git clone --depth 1 https://github.com/raspberrypi/linux.git
sudo ln -s linux $(uname -r)
sudo ln -s /usr/src/linux /lib/modules/$(uname -r)/build
Prepare linux build headers
cd linux
sudo wget -O Module.symvers https://raw.githubusercontent.com/raspberrypi/firmware/master/extra/Module7l.symvers
KERNEL=kernel7l
sudo make bcm2711_defconfig
sudo make prepare
sudo make modules_prepare
Install Driver
sudo git clone https://github.com/cilynx/rtl88x2bu.git
cd rtl88x2bu
VER=$(sed -n 's/\PACKAGE_VERSION="\(.*\)"/\1/p' dkms.conf)
sudo rsync -rvhP ./ /usr/src/rtl88x2bu-${VER}
sudo dkms add -m rtl88x2bu -v ${VER}
sudo nano Makefile
Change 2 lines to this:
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ARM_RPI = y
sudo ARCH=arm dkms build -m rtl88x2bu -v ${VER}
sudo dkms install -m rtl88x2bu -v ${VER}
sudo modprobe 88x2bu
The problem
When I run the last command sudo modprobe 88x2bu I get this error message:
modprobe: ERROR: could not insert '88x2bu': Exec format error
So I guess that the Makefile setting CONFIG_PLATFORM_ARM_RPI is not compatible with Raspberry Pi 4 but only earlier models.
Can I modify the Makefile and add a new platform type that allows the driver to be built for Raspberry Pi 4? Or how do I approach this issue?
I have seen other RealTek drivers that supports Raspberry Pi 4 through a variable in the Makefile named CONFIG_PLATFORM_ARM64_RPI. I am a programmer myself (not a Linux programmer though) but I simply don't know what I want the Makefile code to do when CONFIG_PLATFORM_ARM64_RPI is set to y.
Example of a RealTek driver that supports Raspberry Pi 4 (These does not work with my WIFI adaptor however so just fyi):
https://github.com/aircrack-ng/rtl8812au
Official driver attempt
I also have the official drivers available to me from this link:
https://archive.org/details/realtekdrivers_rtl8811_rtl8812
But in the ./driver folder after unpacking the tar file, I look in the Makefile and here i dont find any RPI options under CONFIGURATION_PLATFORM_*
I tried to add a new line
CONFIG_PLATFORM_ARM64_RPI = y
and ran the install.sh script but it fails (of course because the Makefile does not handle the new CONFIG_PLATFORM_ARM64_RPI line).
and dmesg shows this error message:
[ 542.113848] 88x2bu: disagrees about version of symbol module_layout
More information
Here is some more information about my setup.
Result of uname -smr:
Linux 4.19.115-v7l+ armv7l
I hope that you can help me with tips on how to proceed with this issue!
Hopefully the answer will also help other people in the future.
EDIT 2020-05-31:
I have also tried to use
    sudo make modules
to build Module.symvers instead of getting it with wget.
That did not help.
And I tried to upgrade my kernel to 5.4.42-v7l+ with
sudo rpi-update
sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/local/bin/rpi-source && sudo chmod +x /usr/local/bin/rpi-source && /usr/local/bin/rpi-source -q --tag-update
sudo rpi-source
However, after upgrading it fails in an earlier step so I have rolled back the upgrade.
Stefan R.
  • 191
Finally I had a breakthrough!
Instead of using modprobe and dkms, it was enough to follow these steps:
sudo git clone https://github.com/EntropicEffect/rtl8822bu.git
cd rtl8822bu
sudo nano Makefile
Update lines 100 and 101 to this and save the file:
sudo apt-get install raspberrypi-kernel-headers
sudo make
sudo make install
sudo reboot
After reboot I did iwconfig and now I see two wireless USB adapters.
And a quick speed test with speedtest-cli makes me very happy:
Ping: 7.414 ms
Download: 133.61 Mbit/s
Upload: 153.04 Mbit/s
Greenonline
  • 2,969
  • 38
Stefan R.
  • 191
sudo apt-get install dkms
cd rtl88x2bu
sudo dkms build -m rtl88x2bu -v ${VER}
Remember to reboot.
Source: AC1300 TP-link adapter doesn't work
My speed: 140 Mb/s U:78Mb/s at this AC1300 Wi-Fi
My speed at cable Cu, classic wired UTP connector> D:288mb/s U: 165Mb/s
Country: Romania
SSD 512 WD, +12 GB RAM DDR3, microprocesor old: 2x3000 MHz
