1. Summarizing the problem
No display (https://www.amazon.de/gp/product/B07XPM2ZS3) after LVM tutorial anymore.
2. Providing details and any research
After using this Tutorial (Easy backups and snapshots of a running system with LVM) from Ingo (https://raspberrypi.stackexchange.com/users/79866/ingo) everything was/is fine with my Raspberry (Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM, WLAN-ac, Bluetooth 5, LAN, 4 x USB, 2 x Micro-HDMI ) with a Raspian Buster, Pi-hole, Wireguard installation beside not having a Bruphny 4.0 display anymore (https://www.amazon.de/gp/product/B07XPM2ZS3). Still access to the cli. The display is just turning on and off in intervals.
3.Describing what I’ve tried
Tried to redo the whole LVM installation but came out with the same result. The display is recognized by the Raspian Buster default Installation.
Lawful
  • 43
It should not make a difference if you run the root filesystem from a primary partition or from a logical volume. The operating system only sees the ext4 filesystem, no matter where it is located. Because you restore a complete backup of the SD Card to the logical volume there should also not be a difference.
The only thing I see is, that the display driver has to load at an early stage that is now done with an initramfs, needed to load the LVM driver to access the logical volumes before accessing the root filesystem. So I would check if the display driver is needed in the initramfs and then available there. You can check the contents of the initramfs with:
rpi ~$ lsinitramfs -l /boot/initrd.img-4.19.97-v7l+
I have also optimized the size of the initramfs by including only listed modules. This it set in /etc/initramfs-tools/initramfs.conf with option MODULES=list. You can try to add most filesystem and all harddrive drivers with:
MODULES=most
But this will increase the size of the initramfs a lot and you will need enough space on the fat32 boot partition. Play with the other options given for MODULES= together with loading modules in /etc/modules or /etc/modules-load.d/. But be sure to always include the lvm driver, otherwise you are lost with an unbootable system. Don't worry, there is a way to repair it. But better check with lsinitramfs before booting.
Update:
@Lawful confirmed in a comment that just setting MOUDULES=most as described above, was the solution. Obviously this also includes the display driver into the initramfs so it can start early.
Ingo
  • 42,961
  • 207
