I'm using the Raspberry Pi 4B with 2GB of RAM. I have no problems with WIFI connection, though. But I can't make connection using nm-applet (and nm-connection-editor). On nm-applet it shows "device not ready" under "Wi-Fi Networks". Anyway, I can connect to WIFI using the built-in (LXDE or PIXEL, I believe) WIFI manager.
Summarising, I'd like to have possibility to connect to WIFI on wlan0 (Raspberry Pi 4B built-in WIFI interface) using NetworkManager.
Cimlah
  • 55
If you want to use Network Manager you need to disable the default Raspbian dhcpcd network management tool. The 2 systems are incompatible.
There is no advantage in Network Manager, and it does not really suit the Pi modus operandi - in particular swapping SD Cards between Pi won't work - each Pi needs to be configured individually (although I cannot be sure what Network Manager would do on Raspbian).
You will probably have to enable predictable network interface names
