I have all the newest software. Downloaded the official image yesterday.
apt-get upgrade
apt-get update
rpi-update
rebooted, of course
Does not help.
root@raspberrypi:/home/pi# iptables --version iptables v1.8.2 (nf_tables)
I tried this: root@raspberrypi:/home/pi# iptables -L
Got this:
iptables: Operation not supported.
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
iptables v1.8.2 (nf_tables): Chain 'MASQUERADE' does not exist
Try `iptables -h' or 'iptables --help' for more information.
I need masquerade to work how do I fix this.
This part of a raspberry pi 4 wifi ap setup.
I also get similar errors with nft.
Ended up with some file corruption, and the whole thing wouldn't boot.
Had to reflash the SD card.
Did another rpi-update
Everything was fine this time.
It is not possible to trouble shoot this further.
The question needs to be closed. I can't delete it.
cybernard
  • 196
Had the same problem... apparently you were using netfilter and after the upgrade the iptables command is pointing to the new nftables (https://askubuntu.com/questions/1295021/warning-iptables-legacy-tables-present).
Use this to change to netfilter version:
update-alternatives --set iptables /usr/sbin/iptables-legacy
iceburn_pt
  • 126
You are doing many things wrong. You have first to update the package list before upgrading them. Then you should better use apt full-upgrade instead of only simple apt upgrade.
rpi ~$ sudo apt update
rpi ~$ sudo apt full-upgrade
Then you use rpi-update that may leave an unstable operating system because its only for testing things under development. Please note this Q&A: Unstable rPi 4B after rpi-update.
On my Raspberry Pi 4B this command works without any problems:
rpi ~$ sudo /sbin/iptables --table nat --append POSTROUTING --out eth0 --jump MASQUERADE
rpi ~$ sudo /sbin/iptables --table nat --list POSTROUTING --verbose
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 MASQUERADE  all  --  any    eth0    anywhere             anywhere
I don't know what other things you have mixed up but I suggest to download the image again, verify its checksum and flash it to your SD Card again. Without doing any other things first verify that iptables is working as shown above.
Ingo
  • 42,961
  • 207
