I am looking into using the Ifrared sensor. But i found datasheet andinformation about the manufacturer scarce. I need to know if the sensor is rohs compliant and if it or the manufacturer has other security certifications. Do you know where i can look best?
thank you.
Hi tE
Given this is basically two IR LEDs and a LM393 comparator, I think your only hope is to select a supplier off Alibaba and work with them. Gut feel is you will get nowhere and would do better to build your own.
I think you would do better to ask this on the electronics forum rather than the Pi one as it’s not specifically a Pi question.
You can find the forum here
