I got myself one of those cheap USB microphones and it basically works out of the box with arecord, it's just way too quiet. The level on the virtual UV meter never passes 1%.
Here's what I got, starting from the hardware up to the alsa config:
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8086:0808 Intel Corp.
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
$ dmesg
[165443.535864] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[165443.679497] usb 1-1.4: New USB device found, idVendor=8086, idProduct=0808, bcdDevice= 1.00
[165443.679513] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[165443.679526] usb 1-1.4: Product: USB PnP Sound Device
[165443.679539] usb 1-1.4: Manufacturer: C-Media Electronics Inc.
[165443.698880] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:8086:0808.0001/input/input0
[165443.766033] hid-generic 0003:8086:0808.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-0000:01:00.0-1.4/input2
$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
$ arecord -L
null
    Discard all samples (playback) or generate zero samples (capture)
mic_hw
mic_sv
default:CARD=Device
    USB PnP Sound Device, USB Audio
    Default Audio Device
sysdefault:CARD=Device
front:CARD=Device,DEV=0
    Front speakers
surround21:CARD=Device,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Device,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Device,DEV=0
    Direct sample mixing device
dsnoop:CARD=Device,DEV=0
    Direct sample snooping device
hw:CARD=Device,DEV=0
    Direct hardware device without any conversions
plughw:CARD=Device,DEV=0
    Hardware device with all software conversions
$ arecord -Dplughw:1,0 -c1 -r44100 -fS16_LE -twav -Vmono test.wav
Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Mono
#+                                                 | 01%
Note that I had a speaker 5cm away from the microphone, playing pretty loud music. The level never exceeds 1%. When I playback the test.wav file, I can hear the music, so the basic recording mechanism works. It's just way too quiet.
Whenever I run alsamixer, I see that the recording device is cranked to 100, but it only goes up to 23.81 dB of gain.
I tried to play around with the alsa config, found some examples online, but it just doesn't seem to work.
Here's my /etc/asound.conf
pcm.mic_hw {
    type hw
    card "USB PnP Sound Device"
    channels 1
    format S16_LE
pcm.mic_sv {
    type softvol
    slave.pcm mic_hw
    control {
        name "Boost Capture Volume"
    min_dB -3.0
    max_dB 50.0
Alsa uses the config, because whenever I add a mistake, alsamixer complains about it and aborts. However, the configured max_dB of 50 doesn't seem to work, can't find it anywhere in alsamixer.
Also, the playback device for this card always says auto gain control.
Any hint on how I can increase the mic gain is appreciated.
mefiX
  • 101
