I would like to run a script that would run only on the first boot. For example, Tom could use it to generate unique SSH certs in How can I copy the same image to many SDs?.
I was thinking that I could get the script to delete itself, is this a good idea?
Alex Chamberlain
  • 15,638
Why should it be a bad idea? Check if your script was succesful and put as last command
rm -f $0
macrojames
  • 96
Why not check if the output exists before you try to write it? Here is some pseudo-code:
if( file_exists( '/etc/myfile' ) ) {
    delete( $SELF );
    exit( 0 );
} else {
    create_file( '/etc/myfile' );
It makes sure your output exists before it deletes itself. This way, you can be (more) sure that your script did its job (or wasn't required for some reason).
Oliver Salzburg
  • 1,794
  • 33
