Hardware:
Pi-4 OS -raspbian
I followed the following guide :https://www.raspberrypi.org/documentation/configuration/wireless/access-point-routed.md
Now it works great , I could Connect to the hot spot until I restarted the PI then Im receiving error on my phone "Couldnt get IP Address"
If I try wrong Password I do get wrong password error.
Files:
 dnsmasq.conf:
interface=wlan0 # Listening interface
dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
                # Pool of IP addresses served via DHCP
domain=wlan     # Local wireless DNS domain
address=/gw.wlan/192.168.4.1
 # Alias for this router
hostapd
    interface=wlan0
    ssid=NameOfNetwork
    hw_mode=g
    channel=7
    macaddr_acl=0
    auth_algs=1
    ignore_broadcast_ssid=0
    wpa=2
    wpa_passphrase=AardvarkBadgerHedgehog
    wpa_key_mgmt=WPA-PSK
    wpa_pairwise=TKIP
    rsn_pairwise=CCMP
net.ipv4.ip_forward=1 is enabled
Eitam Ring
So Apparently You need to set the IP of the PI after restarting the hotspot after connection to WIFI , Just run ifconfig wlan0 for me it was ifconfig wlan0 192.168.X.X And everything will work
Eitam Ring
