I'm a beginner in linux and Raspberry Pi but I have some experiences with files systems and embedded systems in general.
I would like to achieve a read-only file system with Raspbian (Buster) and from there I would like to send some e-mails. First of all, I want to start sending e-mails via bash.
I'm using a Mac terminal to connect via ssh to my Raspberry 4 Model B. I followed this tutorial, to achieve a read only file system. This seems to work and I can switch between a ro and a rw system.
To send e-mails, I would like to use msmtp and iCloud. Therefore, I followed a post in this forum. I can't refer to the exact post, so I will show the steps here.
Install package
sudo apt-get install msmtp msmtp-mta
For gmail accounts, these are the specific elements you should put into /etc/msmtprc
# Generics
defaults
auth on
tls on
# following is different from ssmtp:
tls_trust_file /etc/ssl/certs/ca-certificates.crt
# user specific log location, otherwise use /var/log/msmtp.log, however,
# this will create an access violation if you are user pi, and have not changes the access rights
logfile ~/.msmtp.log
# Gmail specifics
account gmail
host smtp.gmail.com
port 587
from root@raspi-buster
user your-gmail-accountname@gmail.com
password your-gmail-account-password
# Default
account default : gmail
I changed the Gmail specific settings to iCloud specific settings
# Generics
defaults
auth on
tls on
# this will create an access violation if you are user pi, and have not changes$
# Gmail specifics
account icloud
host smtp.mail.me.com
port 587
user myName@icloud.com
password MyPassword
# Default
account default : icloud
Now test it!
echo 'your message' | msmtp destination-email-address@icloud.com
msmtp: cannot create temporary file: Permission denied
I get this result, even I set the file system to rw. Is it possible to map the temporary file to the RAM? It would be great, if anyone could explain me the issue in detail and give me an advise how to go on :)
