I've got an IKMultimedia IRig Pro Connected to PI4B It appears in Jack under ALSA-MIDI but I can't find the System-Audio Input
Running lsusb shows me
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 004: ID 0bf8:1028 Fujitsu Siemens Computers
Bus 001 Device 003: ID 1963:000a
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
dmesg says
[ 1.226824] systemd[1]: Detected architecture arm.
[ 1.236156] systemd[1]: Set hostname to <raspberrypi>.
[ 1.298834] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 1.445493] usb 1-1.1: New USB device found, idVendor=1963, idProduct=000a, bcdDevice= 1.00
[ 1.445511] usb 1-1.1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.445524] usb 1-1.1: Product: iRig PRO
[ 1.445536] usb 1-1.1: Manufacturer: IK Multimedia
[ 1.454129] usbhid 1-1.1:1.0: couldn't find an input interrupt endpoint
[ 1.578745] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
[ 1.728163] usb 1-1.2: New USB device found, idVendor=0bf8, idProduct=1028, bcdDevice= 1.00
[ 1.728178] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
cat /proc/asound/cards says
0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
bcm2835 ALSA
1 [PRO ]: USB-Audio - iRig PRO
IK Multimedia iRig PRO at usb-0000:01:00.0-1.1, full speed
When I press the right mouse button on the volume button at the taskbar, I can Use iRig Pro as an output device but opening the volume settings there are no tabs for input devices, maybe because there are no input devices?
I tried adding dwc_otg.speed=1 to my /boot/cmdline.txt file as this should help on usb 1.1 DAC issues but no luck.
alsa-base.conf is empty at the moment
running alsamixer lets me select iRig Pro as Soundcard with F6 but it just says this device has no controls.
Any Idea to get this working?
