I am working on setting up an automated deployment of an executable using the PIGPIO C bindings to a Pi Zero. I copy the executable to the pi (into a directory on pi user's desktop) as expected, but when I try to run it, I get a permissions error:
initCheckPermitted:
|Sorry, you don't have permission to run this program. |
|Try running as root, e.g. precede the command with sudo. |
It seems this problem can be solved by setting the executable to be owned by root and using a permission setting like 4775. This seems to allow me to run the executable while logged in as pi.
Unfortunately though, when I then copy a new version of the executable in, the ownership permissions stay the same, but the sticky bit is removed and I can no longer run the executable. It seems like the right answer would be "figure out how to run the executable when it's owned by pi". Is this possible? Can I change something so PIGPIO can access the needed hardware without having to do weird things with the permissions?
This question seems to be a similar issue, but with PWM specifically. I see a gpio group but pi is already in that group. Is this question related or completely misleading me?
